what to replace on 700r4
Old Feb 13, 2011 | 05:52 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
I just dropped my transmission today..I want to replace all necessary things that can be replaced on it before I install it with my new motor...I was thinking the pan gasket and filter..em I missing anything else?
Old Feb 13, 2011 | 06:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: what to replace on 700r4
I know you don't want to hear this, but ... when I swapped to my carbed 350, the 350 was too much for my 700R4 and I had to get it rebuilt. With the 305, the tranny didn't slip at all. The second I got the 350 running, on the 1st test run the tranny slipped so bad I wasn't sure I was going to get it 2 blocks back to the driveway. Doesn't happen to everyone, I was one of the lucky ones. Something to think about.
Now - while it's out,
1) have a drain plug installed in the pan
2) definitely a filter change
3) what are you doing for torque converter lockup? the kits all require installation of a new solenoid and internal wiring - that needs to be done now.
4) if desired, now is the time for a shift kit
5) the Vette servos, boost valves, accumulators - whatever they are - that go in the round cover on pass side
6) if your changing rear gears, now would be the time to change the drive/driven speedo gears to match so your speedo reports accurately
Old Feb 13, 2011 | 06:05 PM
Engine: 350 tpi
Well I am going with a normal 305 tpi motor nothing big..I had already had a shift kit put in it...so I will not be messing with that for sure I want a drain plug on the tranny...and a filter is a must I'm thinking that would be all I would need cause I had a leak before on it it was the pan gasket.
Old Feb 14, 2011 | 08:24 AM
torque_is_good's Avatar
different schools of thought. I yanked my motor and tranny. Engine ran but had high miles and got rebuilt. My tranny also shifted fine but, I sent it out for a rebuild kit as well as new sprag.
It's like health insurance. If you can spring for the $ few hundred then it gives you peace of mind.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
jklein337
Sep 19, 2018 06:23 PM
Thornburg
Aug 25, 2015 01:46 AM
g.l.mos
Aug 22, 2015 12:02 AM
Leggman1
Aug 6, 2015 04:15 AM
