VSS???
Old Feb 19, 2011 | 09:00 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
VSS???
I'm getting a code in my iroc for the vss where is this located and how do I fix it?
Old Feb 19, 2011 | 09:16 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: VSS???
Edit: what JamesC said.
Old Feb 20, 2011 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: VSS???
82-89 Camaros have the VSS on the back side of the instrument cluster; 90+ Camaros have the VSS located on the trans tail shaft. If you have a code 24, disregard it if the wheels aren't turning when the light pops on.
JamesC
Old Feb 20, 2011 | 09:09 AM
Re: VSS???
Well its an 85. I have the transmission out right now to rebuild it... is it that plug on the drivers side about half way back?
Old Feb 20, 2011 | 09:18 AM
JamesC's Avatar
Re: VSS???
As I mention above, the VSS for 82-89 Camaros is on the back of the cluster (yellow box).
JamesC
Old Mar 6, 2011 | 02:22 PM
suhz88's Avatar
Car: 88 IROC-Z
Engine: 5.7
Transmission: 5-spd
Axle/Gears: D44 3.73
Re: VSS???
I'm getting a code 24 after a rear end swap but only after I drive for a bit. Is there someplace on this site that will tell me how to fix?
Thanks!
Old Mar 6, 2011 | 02:41 PM
Re: VSS???
You said disregard it if it comes on when the wheels arn't rolling? I cant tell if thats true cuz its on all of the time for a couple of things and my speedometer doesnt work. Does this have anything to do with that?
Old Mar 6, 2011 | 02:59 PM
JamesC's Avatar
Re: VSS???
...and my speedometer doesnt work. Does this have anything to do with that?
Your speedo not working has nothing to do with the VSS on your 85. Check the following link for more info about mechanical speedo malfunction:
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
Old Mar 6, 2011 | 03:30 PM
JamesC's Avatar
Re: VSS???
The following off-site info may be helpful. Scroll down to code 24 diagnostics:
http://www.freeautomechanic.com/diag...blecodes5.html
JamesC
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
