simple for some
Old Mar 5, 2011 | 11:52 AM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
simple for some
when someone says they have a 2400 stall put into a tranny,what dose that mean?
Old Mar 5, 2011 | 12:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: simple for some
it means the advertised stall speed of the torque converter is 2400 rpm.
Old Mar 5, 2011 | 12:19 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: simple for some
yup and most cars even stock benefit from a stall converter. But if it is too much it is no good. or if its a low quality.
Old Mar 5, 2011 | 03:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: simple for some
A TC is actually two seperate parts, one spins inside the other - one part connected to motor, one connected to tranny. There are what looks like turbo fan blades inside. The motor turns, say at idle - there isn't enough 'torque' at idle for the fluid to get spun fast enough to catch the fan blades of the transmission side to make the transmission spin. At a higher "stall" speed (ie higher RPM), the pressure of the fluid getting spun by the motor side starts to spin the fan blades on the tranny side, thus starts making the transmission turn and make the car move.
So, in basic terms, a 2400rpm stall speed converter means the engine has to be turning at 2400rpms in order for the car to start moving. It's not quite that simple, cause if you take your foot off the brake at idle, the car will move ever so slightly. But think about having your foot on the brake, it takes until 2400rpm for the car to start really fighting the brakes.
Thus, you match your stall speed of your converter to your beginning of your power band. If you have a power band (determined by cam, intake, etc.) of like 1500 - 6000 - you don't want your car 'moving' under motor accelleration until sometime after 1500 rpms - that way your not wasting hp at a point that's not optimal powerband for your engine.
At the strip, it kinda means you can have your foot on the brake, rev the motor to just under 2400 rpm, and let off brake and mash gas at same time - your already in your "powerband" and thus getting the most performance per rpm out of your car.
None of this is 'literal' of course - but gives you an intuitive idea of the concept. There's alot of other stuff at play that maximizes your 'performance' at the track.
Old Mar 6, 2011 | 10:02 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: simple for some
thanks,this last coment made it most clear,so a stock iroc 350 tpi would do good with a 2400 stall in normal street driveing or not?
Old Mar 6, 2011 | 12:26 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: simple for some
The best thing you could do to "get" what a higher performance stall converted does for the car from a performance and drivability perspective is to drive a car with one.
Old Mar 6, 2011 | 12:30 PM
Car: 1992 RS
Engine: Carbed 350
Re: simple for some
Yes, 2400 stall is fine. A decent stall for a stock street car.
Old Mar 6, 2011 | 06:42 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: simple for some
wigmobile
Feb 26, 2025 02:56 PM
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
