rear end gear oil
Old Feb 23, 2011 | 12:34 PM
bamawillie's Avatar
rear end gear oil
is it ok to run synthetic gear oil in the positrac/performance rear end?...for example royal purple 75w90....or will it leak
Old Feb 23, 2011 | 02:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Leaking isn't the issue. Eaton and Auburn both say do not use synthetic fluid with their carriers because their friction discs aren't compatible with it. I believe factory posi units were made by Auburn.
Old Feb 24, 2011 | 08:24 AM
bamawillie's Avatar
Re: rear end gear oil
thanks for the info....i will stay with the regular
Old Feb 24, 2011 | 08:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
five7, has your opinion changed about using synthetic in the diff? I 'seem' to recall that you were a proponent at one point. There are members, including me, who use Mobil 1 75-90 with GM additive and whose cars are equipped with an Auburn. No issues for me after a number of years.
JamesC
Old Mar 6, 2011 | 01:55 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
I have a question. What weight would you reccomend for general use on a stock 9 Bolt with 3.70's in it with a TA diff cover? Anything different than normal? Any addative? GM posi or Ford Friction Modifier?
If there is a FAQ about rearends i would love to read it, just point me in the right direction.
Keo
Old Mar 6, 2011 | 02:53 PM
JamesC's Avatar
Closest thing to a FAQ for 9-bolts:
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
Old Mar 8, 2011 | 05:53 PM
Keoman's Avatar
JamesC
Go for sticky!
Thanks James
Old Mar 16, 2011 | 01:51 PM
five7kid's Avatar
(Sorry, didn't see the follow-up responses.)
I am a huge proponent of synthetic lubes. I picked up a used factory posi unit, worked fine for about a month after install and switching over to synthetic lube, then turned into a one-wheel-peel unit.
I had a new Auburn unit put in the '57. I called AMSOIL to get their take. They said exactly what you said (except about AMSOIL, not Mobil 1, of course). It failed to hold after about a year.
The instruction sheet that came with the new Eaton unit I installed in the Camaro last fall was very specific about not using synthetic gear lube. It held fine through the fall racing season, and winter driving, still good and tight today with petroleum-based gear lube.
I wish they'd get their act together and use friction materials that are compatible with synthetic gear lube. Until then, I'm going to go with a locker-type carrier such as a Detroit whenever possible (didn't have time to get one when doing the diff last fall, wasn't one available locally).
Old Mar 17, 2011 | 10:30 AM
Keoman's Avatar
five7kid,
what is the milage span difference between the synthetic and normal gear oil? I guess what im asking is how long is each one good for?
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
