another BW 9 bolt question
Old Feb 27, 2011 | 07:32 PM
Sierra XB's Avatar
I just picked up a used BW 9 bolt rear end for my 85 IROC. Although the posi seems good still, I am going to replace the carrier and pinion bearings. By searching around the forum i have found good sources for the bearing kits, so no worries there. What i want to know is if the rebuild proceedure (shimming for pinion depth, gear contact patterns, etc.) is the same for the 9 bolt as it is for a 10 bolt. This will be my first attempt at rebuilding a rear end, so I want to get it right the first time. Also can anyone steer me to a good thread/sourse for the rebuild and assembly proceedure? Thanks..
Old Feb 28, 2011 | 08:30 PM
IAGTA's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
Re: another BW 9 bolt question
There are multiple posts on this process but the best that I've seen is the following:
https://www.thirdgen.org/forums/faq-...now-about.html
Or this one (nice photo):
https://www.thirdgen.org/forums/tran...i-rebuild.html
Good Luck!
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
