choosing a posi unit, opinions please!
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
i have my choice between three different gm 12 bolt rear ends to put into my 91 camaro from summit. one choice is an auburn hd with 3.73 gears 33 spline axle or an eaton with 3.08 gears 30 spline axle or a true-trac 3.55 gears 33 spline axle. have any of you guys used these center sections before? the motor is making roughly 400-500 hp at crank with a stock t-5 havent got it dyno'd yet. just curious which holds up better or easier to work with. any comments always helps. thanks
Re: choosing a posi unit, opinions please!
You DO NOT want the Auburn. The Eaton is best for street/strip use. The Truetrac is good for auto cross and road racing. I don't understand what you mean about these being from Summit. Are these new rear ends, like Moser? If they are then you can have it built any way that you want.
Engine: gone
Transmission: gone
Axle/Gears: gone
eaton posi for sure. Auburn's have cones in them you do not want cones!
Engine: 00 383
Transmission: t-5
well here these are my options that im looking at. http://www.summitracing.com/search/y...?Ns=Rank%7cAsc i dont want the 4.0+ gears im looking at the 3's. im trying to see which one would be the best option for me because thats alot of money to spend on something thatll break
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I just got of the phone with Summit Racing and they hooked me up with this part # I think your going to like it. I know I do.Ill have to put it on my wish list.(only in my dreams) = http://www.summitracing.com/parts/MSR-12BHACCBBCXH/
If its not what your looking for than give them a call and tell them what you want.Thats what I did. Says it comes with a aluminum girdle cover. Thats nice.
Engine: gone
Transmission: gone
Axle/Gears: gone
dang 2900 for jus an axle and housing?
Engine: 00 383
Transmission: t-5
no 2900 axles houings gears bearings and everything including brakes. oops thought you were talking about the ones i posted undercovertbi. yeah 2900 is alot with it not including brakes. but i do like the gear and differential set up just need better splines and brakes and id be getting it
where would i find a moser dealer near me?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I havent used the true trac on an f-body, but they always worked well for me on my jeeps, both on and off road. They seemed to be very durable and worked smoothly. while i didnt have them behind 400hp, I did do a lot of burnouts in my street jeep and wheeling and they gave me no problems and looked great when i took them apart.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
i would be careful moser does not have a good rep on ls1 tech with the 12bolt the torque arm bolts like to back out.
they have also been known to make a lot of noise. mostly on 6-speed cars.
for the money you can have a fully setup s60 with a drive shaft or a fabricated 9"
georgiaslim45
Sep 9, 2015 08:11 PM
