how to remove rear end?? need help please
Old Mar 18, 2011 | 08:21 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
a friend found a posi rear with disc brakes at junkyard today and this weekend they have half off everything so i want to go and see if its still there to remove and bring it home with me but 1 i dont know how to remove a rear end. and 2 i dont know what else i should get from the car itself. its a trans am he told me.
can any one explain how to remove it and maybe tools i might need?? and also what else i should remove so i can have an easy install when i get me car back from my uncle?
hopefully someone can help me. i want to know by tomorrow 3/19 early because i have work early sunday :/
please and thanks
-Aaron
Old Mar 18, 2011 | 08:23 PM
Mailman818's Avatar
Engine: 2.8L V6
Re: how to remove rear end?? need help please
or a link where i could find out. please and thanks
Old Mar 18, 2011 | 08:58 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Support body on jackstands/big blocks (spare wheels & tires found in the junkyard are good for "jackstands") with the tires just touching the ground. Spare wheels/tires (laying on their side) are more stable than jackstands & if you use real jackstands, you'll need them or something to hold the car up while you pull your jackstands out anyways
Unbolt the e-brake cable at the Y connection under the car in tranny tunnel
Unbolt rubber brake (or just cut the rubber line) line before the y-connection on the axle
Unbolt the shocks from the axle end
Unbolt the LCAs at the axle end
Either jack the body up even higher now, to clear the tires or support the rear end while taking the wheels/tires off & lower it to clear under the rear bumper
Proceed to pull the axle back. The rear springs will have fallen out if you jacked the car up high enough, or be very loose & can be pulled/wedged out
Most likely you'll be buying just the rear end, so you can take the wheels/tires off at this point (or after you roll it to the back of your truck, to load into your truck. If it currently has none, grab 2 that will fit & temporarily use them as described above.
Did I overlook anything??
Old Mar 18, 2011 | 09:09 PM
Mailman818's Avatar
Engine: 2.8L V6
umm should i leave the sway bar on and use it for my swap later one or remove it?
also would you happen to know of any other parts i should grab that will help in my swap?
i want to make it easier on me since its going to be coming out a firebird and going into one.
thanks - Aaron
Old Mar 18, 2011 | 09:17 PM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
master cylinder and porporsoning valve. disk/drum is different than Disk/Disk... Correct me if im wrong.
Old Mar 18, 2011 | 09:19 PM
Car: GTA
DOH! I did overlook something. The swaybar!
Easiest way to get it loose is to pull the nut off the endlinks & leave it attached to the rear end. If you can get it without the extra cost? Go for it.
If your going from drums to disc, you could the proportioning valve. Some people do (they think the difference in line pressure warrants swapping it out too), some don't.
You could see about grabbing a 98+ disc rear instead. Bigger/better brakes & the stock 16's will end up virtually even with the fender lip. So they'll SET out, but not STICK out. They'd still be under the fenders.
If you have 15s? I'm not exactly sure of the bs on those wheels & where they would end up. I've only had 16" wheeled 3rd gens.
Old Mar 18, 2011 | 09:26 PM
Mailman818's Avatar
Engine: 2.8L V6
true lol
where are those at? i dont have much experience with cars and im still learning little by little.
Old Mar 18, 2011 | 09:29 PM
Mailman818's Avatar
Engine: 2.8L V6
cool ill see if i can find one there cuz all 4th gens usually are parted out quick. i see lots of parts on third gens there.
thanks alot for the quick responses man i appreciate it alott!!
Old Mar 18, 2011 | 10:22 PM
Car: GTA
Yes the prop valve is different, but that is it.
Some people change them, some don't. Comes down to personal preference really.
Old Mar 19, 2011 | 04:41 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Dont forget to unbolt the torque arm and the drive shaft as well
Old Mar 19, 2011 | 06:22 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Panhard bar also....
Old Mar 19, 2011 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For best brake performance, use the correct combination valve. The bias increases between the three types:
disc/drum
disc/disc
disc/1LE
The following 10-bolt FAQ will provide info on master, combination valve, parking brake cables, and speedo drive/driven gears.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 19, 2011 | 06:22 PM
Mailman818's Avatar
Engine: 2.8L V6
cool thanks for responses guys. i went today and dropped that sucker and took it to my friends house for storage. just in case i dont put it on how much would it sell? im not sure what kinda gears they are but i know its a posi for sure. it has disk brakes with brake lines still intact, a sway bar with bushings and bolts, two rs rims with tires, and all bolts i took off. unfortunately i didnt have a chance to take a picture roughly with all parts i got being said how much would something like that go for?
-Aaron
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
