Fixed the tv cable problem but...
Old Mar 31, 2011 | 03:20 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I posted a while ago about a tv cable problem and that has since been fixed. After that, the car shifted perfectly. Yesterday though after I got on the gas a couple times, the car wouldn;t shift right (just as before the tv cable fix). I found out that if I put it into park or just restart it, it is fine.
Can somebody explain?
For those who don't know...the tv cable would get stuck causing late and hard shifts. The cable was fixed for sure, so I still wonder what was causing it.
Old Mar 31, 2011 | 03:30 PM
Blue1990camaro's Avatar
Re: Fixed the tv cable problem but...
mine does similar, it shifts a little late and the time it takes to shift from one gear to the next is really long shifts VERY SOFTLY does yours do this? what does it do?
Old Mar 31, 2011 | 03:33 PM
chevydrvr's Avatar
Well after I fixed the cable you could barely tell when it shifted if i'm light on the gas, which I assume is normal.
Yesterday what happened was that it was shifting late and hard. One way I could tell something was wrong was when I hit the gas a little to accelerate and just revved high before picking up speed. There was one point where it wouldnt shift at all so I pulled over poped the hood, and checked the tv cable. It was springy and tight like it should be. ON the way home from school again today it did it, so I pulled onto a side street, through it into neutral, and shut it off without stopping then started her back up and put it into drive. It was fine after that.
Old Mar 31, 2011 | 03:37 PM
yea similar to what mine does, and i think my acumulator in my trans is goin bad, we both shuld have the 700r4
Old Mar 31, 2011 | 03:38 PM
chevydrvr's Avatar
What is the acumulator?
Old Mar 31, 2011 | 03:40 PM
not sure its inside the transmision, all i kno is that it controls the shifts or something lik that
Old Mar 31, 2011 | 03:51 PM
chevydrvr's Avatar
Well it only seems to happen when I get hard on the gas....we'll see.
Old Mar 31, 2011 | 03:54 PM
same here, under normal driving its shifts almost perfectly
Old Mar 31, 2011 | 03:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TV is probably sticking in its bore in the valvebody.
Old Mar 31, 2011 | 05:51 PM
mine shifts very slowly when u try to get on it and when u hit it on the highway it just revs way high then slowly slides into gear, any ideas on how to fix his or my problems??
its boiling down to where im just gona buy a trans
Old Mar 31, 2011 | 05:57 PM
chevydrvr's Avatar
Have you checked your tv cable?
This is what I did yesterday after it started happening and I fixed it (just thought I'd share lol)
http://www.youtube.com/watch?v=JR5kKibVACM
Old Apr 1, 2011 | 01:54 PM
if only i could see youtube vids at skool, anyway you could email me that file to punkrocker621992@aol.com so i can see it?
and yea i adjusted it, it doesnt seem to b binding what so everrr
dyeager535
Aug 28, 2015 08:10 AM
Bert87
Aug 23, 2015 03:50 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
