drag racing, axles
Old Mar 31, 2011 | 07:24 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
drag racing, axles
I was just wondering if my 88 Camaro 2.8L 700R4, it is all stock, the engine and tranny were just rebuilt. I was wondering if my stock axles will handle a burnouts at the dragstrip or should i just drive around the waterbox. im trying dragracing, always have been a fan, havent really tried a burnout on the street just squeeled them pulling out but no brake stand or anything. and any mods i could do to help, im swapping fluid to synthetic and was wondering if 3.73 gears would help and not really hinder MPGs because it is driven just about literally every every nice day. and possibly some sort of posi. any help will be considered, thanks guys.
Old Mar 31, 2011 | 07:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: drag racing, axles
i really doubt the axle will have any issues at all, unless you have wheel hop.
Old Mar 31, 2011 | 07:37 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
it has upgraded swaybars and poly bushings that might help and on the street when accerating hard on the street it doesnt seem to hop. but thanks.
Old Mar 31, 2011 | 09:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your 88 will have 26 spline axles. A better upgrade is to use aftermarket 28 spline axles but that will mean also changing the posi. You can do all kinds of improvment to beef up the 10 bolt but you'll still have those tiny ring and pinion teeth and they will fail before an axles usually will.
Old Mar 31, 2011 | 09:43 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
soo in the condition will i or will i not break an axle or anything?
Old Mar 31, 2011 | 09:49 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
it wont be like hard core or anything prolly wont even footbrake or anything. just wondering if i would break something.
Old Mar 31, 2011 | 10:00 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Doubt you'll break anything with a 2.8
If your not running slicks or drag radials, then theres really no reason to even do a burnout. I would just go around the water box. If for some reason you have to go through it, I just floor it for a split second. Just enough to get the water off the tires.
Dont take this as an insult, but rather an honest question. Can you spin the tire(s) now?
Old Mar 31, 2011 | 10:13 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
honestly i have never tried to in fear of breaking something because it almost is like a daily driver unless its raining or below 45 degrees im driving it haha
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
JSDaddy189
Sep 26, 2015 03:50 PM
