T5 electric speedo to mechanical question
Old Apr 5, 2011 | 12:24 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
I just bought a t5 swap kit for my 85 iroc and just realized that the t5 has a electric vss but my car has a mechanical speedo cable. How do I fix this issue without buying a new speedo?
Old Apr 5, 2011 | 12:41 PM
Re: T5 electric speedo to mechanical question
A. Remove electric sending unit from new trans.
B. Remove cable gear holder "bullet" from old trans.
C. Place Part B into Assembly A.
Old Apr 5, 2011 | 12:46 PM
Even though the old trans is auto this will work?
Old Apr 5, 2011 | 12:49 PM
http://www.transmissioncenter.net/sp...____va.htm#350
Old Apr 5, 2011 | 03:07 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
What year tranny? I need a vss from a 91-92. My current t-5 is from a 84 or 85. Maybe we could trade parts?
Old Apr 15, 2011 | 01:37 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
how the hell did you find a elctric speedo t5? lol dam like the guy above said try and trade parts...if you cant trade him let me now.
Old Apr 15, 2011 | 07:14 PM
LOL right! My speedometer is an aftermarket tach......
Old Sep 26, 2018 | 01:38 PM
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
There is an electronic speedometer sending unit on eBay for a T5 right now type in 25007350 that's the part number
Old Sep 26, 2018 | 01:45 PM
kenbob's Avatar
Engine: 305 LB9
I have a spare t5 mechanical unit if needed
Old Feb 9, 2020 | 12:08 AM
John Cullen's Avatar
Do you still have this part available? I have a WC T5 so it has the electronic speedo plug and my car has the mechanical cable
Old Feb 9, 2020 | 09:35 AM
https://transmissioncenter.net/produ...-gears/page/5/ The Turbo 350 stuff is also for T-5.
Old Feb 9, 2020 | 02:02 PM
Incidentally, you can probably sell that electronic one for MUCHO $$$$$. They're not very common, and demand is MUCH higher than supply.
Old Feb 12, 2020 | 08:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There is a range of TH350 Chevy stuff with the same bullet diameter as the T5, but the gears are different.
Third gen T5 had smaller diameter driven gear, with 22 tooth max, and a large dia. drive gear.
TH350 stuff had larger dia. driven gear, max of 24 or 25 tooth, and a smaller dia. drive gear.
If you get matched gears, cool. If you try to use a T5 gear with a tH350 gear, nope.
Strut_Tower
Apr 26, 2006 11:00 AM
pimpmaster
Aug 3, 2003 06:13 PM
camaro6spd
Jul 10, 2003 09:45 AM
TravisZ28MAXX
Jul 3, 2003 08:40 AM
Cronic3rd
Apr 4, 2003 01:57 PM
