z28 automatic 91' question?
Old Apr 6, 2011 | 03:22 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
ok so i gotta 91 auto (700r4 i think?) with stock 305tpi...am i better of just putting in a replacement 700r4?(mine is slipping pretty bad) or should i put a t350 or 400 in it? and if i do put another set up do i have to change my ecm or anything like that?
Old Apr 6, 2011 | 03:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: z28 automatic 91' question?
Putting in another 700R4 is easiest.
Old Apr 6, 2011 | 06:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Either rebuild what you have, or replace with another 1988+ 700R4.
Old Apr 6, 2011 | 07:16 PM
Gonzales7's Avatar
Car: 1990 Camaro RS
Engine: 5.7 350
Transmission: Built 700R4 with 2700 stall
Axle/Gears: Moser axles with 4.10s POSI
Stay with the 700! If you switch a TH350 or 400 you have to get a different drive shaft and you lose O/D.
Old Apr 6, 2011 | 09:40 PM
Car: 1991 z28
Engine: 305 tpi
thank everyone for the input...now for another question is a shift kit and a different torq converter a good i dea when i do the swap? if so what converter should i look for for a stock 305tpi (and not something verry expensive, i mean im willing to spend money but not too much) thanks for any input given !!
Old Apr 6, 2011 | 09:46 PM
Car: 1991 z28
Engine: 305 tpi
and will a 700r4 out of any vehicle do the trick or are they different? i can only really find tranny's from junked trucks some with 4wd(i dont care about scrappin a t-case buse will it work?)
Old Apr 7, 2011 | 09:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Any non 4wd, non Corvette 700R4 will work. If it's out of something besides an F-body, you'll have to swap your current tailshaft housing onto it.
Old Apr 7, 2011 | 10:28 AM
Car: 1991 z28
Engine: 305 tpi
thank you so much for your advice on the topic i dont mind swapping tailshafts (especially cuz the one in my current tranny is BRAND NEW) but one more question,ive seen people swap it out with the 4th gen tranny i think 46le or somethin like that? apparantly theyre identical? can you shed some light on that?
Old Apr 7, 2011 | 11:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 4L60E is electronically controlled and you can't use it without a computer to control it.
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
