speedometer problems
Old Apr 8, 2011 | 08:35 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
so i swapped my 305 engine to a 350 carbed, ripped the WHOLE ECU AND HARNESS out. so i have a electro speedometer, and it DOES go through the ecu to operate. i do have the connector cut from the old ECU harness, but where do connect the PURPLE and YELLOW wire too?????? here is some pictures to help you understand.
-- First two pictures are the plug on the trans.
-- The third one is the connect i cut out of the ecu.
--THE QUESTION is where do i connect the YELLOW AND PURPLE wire to get my speedo working.
Attached Thumbnails speedometer problems-p1020047.jpg   speedometer problems-p1020048.jpg   speedometer problems-p1020051.jpg
Old Apr 8, 2011 | 08:36 PM
defaria27's Avatar
Re: speedometer problems
This is the harness that is left under my dash and what plugged into my ECU.
- There is no, purple and yellow wire.
Old Apr 9, 2011 | 02:05 PM
defaria27's Avatar
please help me.
Old Apr 9, 2011 | 08:58 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I don't know where the wiring diagrams are on this forum, but you probably need to wire it like a non-ECM-pass VSS car (86-89 Firebird)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
