2.73 to 3.42 need some wisdom!! PLEASE!
Car: 1990 Camaro RS
Engine: 5.7 350
Transmission: Built 700R4 with 2700 stall
Axle/Gears: Moser axles with 4.10s POSI
Alright so I'm thinking of buying this 85 camaro rear end with a 3.42 POSI with disk brakes for $300 for my 90 camaro. I was wondering if I would run into any problems swapping mine out and throwing this one in. Would everything bolt up right? How could I check if the rear end is good? Any help would be nice. Thanks
Re: 2.73 to 3.42 need some wisdom!! PLEASE!
Bolts right up.
You check it for being good, by LOOKING at the parts. If it's good, put new fluid back in, it needs it anyway.
The posi in those is an Auburn. Pretty lame, but I guess not as bad as a Gov-Lock. It's usually worn out within 8 - 10 years of normal driving. Don't expect much. It's not rebuildable; when it wears out, into the trash it goes.
It will have the Delco-Moraine brakes. They suck. Alot of people report that they can put their car on jack stands, drop it in gear, and the brakes cannot stop the wheels even at idle. However, if you get "new" calipers, install the GM "recall kit" in them (who knows why the rebuilders don't put that in them), and do the combo valve mod, they can work MUCH better; and of course, make sure you use the parking brake EVERY TIME you get out of the car, and twice on Sundays, because that's THE ONLY thing that keeps them adjusted up.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'll also need to swap speedo gears for your speedo to read correctly - you'll neeed to replace both the drive gear and the driven gear - one is in the speedo housing on the tailshaft of the tranny (easy to swap), other is on the actual tranny spline inside the tailshaft housing (a bit more difficult).
Car: 1990 Camaro RS
Engine: 5.7 350
So would it be wroth it to grad this rear and do some work to it? Or should i just save a little more money and swap a 3.73 posi with the rear I already have?
Car: 1990 Camaro RS
Engine: 5.7 350
http://www.facebook.com/photo.php?fb...687525&theater
Heres some photos of what the rear looks like.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/atta...e-adjuster.jpg
Since no one in his right mind would swap Delco-Moraines for PBR's, you no doubt have drums. That said, for the best brake performance, you'll need to swap the combination valve as well.
JamesC
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
If it's still in the donor car and you are able to drive and listen to it, that'd be even better and i know IMO i'd be more inclined towards a purchase.
Aren't 4th gen rears going for 3 or 4 hundred these days? Better differential, "stronger" axles, better brakes, but you gotta deal with the offset...
89-97 cars have 28-spline axles, Auburn limited slips, and PBR system brakes. The LT1's (98+), though they still have 28-spline axles, they also have Z/T limited slips and a better braking/parking brake system.
JamesC
JamesC
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
[You'll also need to swap speedo gears for your speedo to read correctly - you'll neeed to replace both the drive gear and the driven gear]
I replaced my drive and driven gear and was a pia. I found out the drive gear can be left in place, and make up for it with a different driven gear. I believe I found the info here:http://www.transmissioncenter.net/sp...n_______va.htm
I did the same replacement from 2.73, to 3.42
Engine: gone
Transmission: gone
Axle/Gears: gone
Yup I did not change the drive gear on the driven gear. with a 26 inch tire which is a 215/65/15 or 235/60/15. I had to run a 45toothe driven gear which is light blue. With the stock drive gear which is green I cannot remember the teethe on that.
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
If your car is a drum brake car now you will also need he prportioning valve from the disc brake car.
Car: 1990 Camaro RS
Engine: 5.7 350
Thanks guys for the wisdom!
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Do you remember where you got your 45 tooth driven gear? I can not find it anywhere. I can, however, find the 44 tooth.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Axle/Gears: 3:42
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
year old thread FTW!
Depending on mods, 3.73's wont be too much for a L98. Need superram/miniram/hsr or siamesed runners to take advantage of it but a street car will be better on the highway with 3.42's or lower.
