trans leaking from linkrod in side of trans
Old Apr 26, 2011 | 04:34 PM
voljim's Avatar
my transmission is leaking fluid from the side where the rod goes in can i repair it without droppping trans? is there a gasket or something ?
Old Apr 26, 2011 | 05:06 PM
Re: trans leaking from linkrod in side of trans
If this is an auto trans, then I'm going to assume you're talking about the shift lever seal...
You have to remove the shift lever to change the seal, which has to be done from the inside. You can drop the pan and get to it.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
timonator
Aug 11, 2015 09:56 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
