700R4 problem
Old May 6, 2011 | 08:46 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
700R4 problem
My car runs great, and idles around 7-750rpm in gear. My problem is that when sitting at a stoplight, I have to have my foot on the brake really hard or the car will inch forward? Thats got to be trans related right? Is it a bad adjusted TV cable, internal problem? TC problem?
In other cars I have driven, (not f-bodys) even the slightest bit of brake pressure holds the car at a stoplight?
Is something wrong, or is this just the way these cars act?
Old May 6, 2011 | 11:45 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700R4 problem
700 - 750 idle in gear is a tad high - I think should be closer to 500 - 600 (but I'm no TPI expert - the TBI cars idle lower). But - that little bit shouldn't make you have to hold it that much harder. My carbed car idles at about 750 in gear, and I'm not grunting to hold it.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
