3.23 gears, trying to spin two tires
Old May 18, 2011 | 11:25 PM
PeteyPabs's Avatar
Car: 86 Iroc with z28 body
Engine: modded 305
Hey guys, i just pulled some of my rpo codes and noticed i dont have a lsd or a posi unit, instead i saw i have the 3.23 unit. I'd like to get either a locker or posi whichever is easier to install/cheaper.. i heard that the powertrax unit is really quick and simple to install and costs only about 300 dollars.. i'm not trying to build the fastest car out there just something decently fast and able to do some donuts in a dry parking lot
so that being said which powertrax or similar unit should i purchase or should i just try to pull the rear out of a junked car at a yard? how would i do that and how difficult would that be without any real special tools?
thanks again
Old May 18, 2011 | 11:42 PM
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
Re: 3.23 gears, trying to spin two tires
honestly if you've never done differential work before I would take it to a pro or have a buddy that's done it walk you through it.
I would get a LSD a "locker" or spool would wear your tires out too much
Old May 18, 2011 | 11:50 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
you dont need a posi to do donuts....3.23 but no Limited slip eh?
Id check craigslist for 4th gen rear ends. you can noramlly get them rather cheap. the 98-02 ones go for a little more because they have the better differential.
other than that. go to your local rearend shop and get it done properly and EATON posi the posi of choice by most on this site. The truetrac by detriot locker is nice also. A full locker is really for street/strip cars with more emphasis on strip.
Old May 19, 2011 | 12:00 AM
PeteyPabs's Avatar
Engine: modded 305
thanks guys, so if i was to get one of these posi rear end units where could i get one for the least amount of money? and if i was to have a shop do it how much around would it cost?
Old May 19, 2011 | 12:18 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
hard to say. you can get one at a pick n pull but no way to tell how good it is. other than that craigslist. Now if you actually want to buy a new posi unit check with summit racing, jegs, streetside auto etc..
Old May 19, 2011 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Before you purchase anything, you might consider reading the 10-Bolt FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old May 21, 2011 | 09:22 PM
PeteyPabs's Avatar
Engine: modded 305
JamesC
thanks! one of the best mods i've ever seen on a forum haha.
and since you guys are here I was also wondering what you guess thought about a spool or minispool on a third gen would be like? The camaro is going to be a designated 5 speed summer car and i'm a good driver (cautious in the rain) and probably just going to be buying cheap tires(or parts hopefully not though) from the junkyard for it. I was also thinking about just going to some hot rod shop in mass and asking them to weld up the spider gears for a "lincoln locker" as i've heard them called, anyone know any horror stories about either
Old May 21, 2011 | 10:32 PM
Guest
Guest
Posts: n/a
https://www.thirdgen.org/forums/sear...archid=4083636
Old May 22, 2011 | 11:20 PM
PeteyPabs's Avatar
Engine: modded 305
links broken i think
Old May 26, 2011 | 10:51 AM
PeteyPabs's Avatar
Engine: modded 305
i noticed you said you dont need a posi to do donuts but wouldn't you just stall out half way around the spin and start spinning one tire?
Old May 26, 2011 | 12:12 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I paid $150 for a used torsen LSD and 3.42 ring and pinion out of a 2001 camaro. I swapped it into my stock 10 bolt. When I had my open 3.23 diff I could do donuts no problem.
Old May 26, 2011 | 07:14 PM
PeteyPabs's Avatar
Engine: modded 305
nice thanks man!
Old May 27, 2011 | 07:16 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have 3.27s and i can easily do burnouts... if u wanna to just spin just get a higher stall converter.....
Bubbajones_ya
Aug 28, 2015 02:17 AM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
