install t5 without clutch slave cylinder?
Old Jul 9, 2011 | 08:41 PM
problem2420's Avatar
Car: 86 ta
Engine: 305tpi
Transmission: t5
Axle/Gears: 2:77 soon to be 3:42
is it possible to do that with the clutch fork there? because i need a new one and was just wondering.
Old Jul 9, 2011 | 10:05 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: install t5 without clutch slave cylinder?
if all else is correct , yes . good luck .
Old Jul 9, 2011 | 10:10 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, slave can go on later.
Old Jul 10, 2011 | 08:47 AM
^^^ Yup
In fact you can change the whole hydraulic system out as a package - master, slave, reservoir, and line - with the entire rest of the car assembled.
Old Sep 20, 2011 | 09:06 PM
Car: 86 ta
Engine: 305tpi
Transmission: t5
how far should the clutch fork be from the bell housing? because it seems that the slave cylinder rod is loner and needs to be compressed more. is that normal? should i have to use alot of force to get it in. or should the new slave cylinder plastic holders be were the clutch fork is?
Bubbajones_ya
Jul 6, 2024 08:32 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
topteam54
Oct 6, 2015 12:21 AM
Jonas Earl
Sep 27, 2015 07:39 AM
