Transmission: WHAT does this plug into?
Old Jul 25, 2011 | 01:34 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Mechanic noticed this plug hanging out of place. It runs along side of my 700r4 transmission. It's a white plug. He says the end of it is broken and won't fit into the transmission plug anymore. He mentioned he thought it was a sensor or something for the locking torque converter?
What is this plug for? He taped up the end of the plug because it was shorting out against the trans. oil pan and was shorting out 3 fuses instantly.
He mentioned that it MAY not be needed and may have been unplugged on purpose when my Shift kit was installed in my 700r4 years ago.
Any thoughts? If this for the torque converter? IS it needed to be plugged in even if I have a shift kit or something?
[Pics]
1. Circle shows plug
2. Circle shows what mechanic believes the plug, plugs into and suspects it to be a torque converter sensor or something? And if so, suspects it's not needing to be plugged in if I have a shift kit?
Attached Thumbnails Transmission: WHAT does this plug into?-plug_1.jpg   Transmission: WHAT does this plug into?-plug_2.jpg
Old Jul 25, 2011 | 03:40 AM
Pro Built Automatics's Avatar
Re: Transmission: WHAT does this plug into?
Whether a Shift kit was installed or not, it is the plug to lockup the torque converter. Get it fixed soon.
Old Jul 25, 2011 | 03:42 AM
What does it do? What if it's not fixed? Any damage being done? NO idea how long it's been disconnected for..
Old Jul 25, 2011 | 05:27 AM
It lets you lockup the torque converter clutch, which lowers temperature and rpm, and gets better gas mileage.
Old Jul 25, 2011 | 11:48 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I'd get that fixed. You're not taking advantage of your 700R4 with that broken and you're generating a lot of excess heat in the process. A lot of miles like that can lead to a premature tranny rebuild if it's not dealt with.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
