Which of these transmission will bolt it?
Car: 88 Trans Am
Axle/Gears: Posi
2002 mustang gt tremec 3650
2002 mustang tremec 5 speed
5.0 ford mustang tremec tko 3550
1986-1995 mustang tremec tko 3550
tremec tko 500
03 mustang gt tremec tko 600
2000 ws6 6.0 trans am t-56
replacing my t5 with one of these that i will rebuild, i need to which ones can be made to work in sbc 350 from an early 90's camaro
I could also use advice on where to buy replacement transmission mounts for the swap
tremec tko 500
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: Which of these transmission will bolt it?
how are you gonna bolt up a ford tranny with ford bellhousing pattern to a sbc with chevy bolt pattern...unless theres something i'm missing here??
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Plus all the non third gen transmissions don't have a provision to attach the torque arm.
The fourth gen T56 is the only one that's basically a direct bolt in. Any transmission can be swapped in if you do a lot of fabrication work and spend enough to do the conversion but if you're asking which ones will work, you probably shouldn't be doing the swap.
Car: `86 SS / `87 SS
With LT1 parts swapped into it, the last one will.
But Alky said a lot.
Bolt into what?
If this is a Mustang, then all of the Mustang transmissions will, but not the GM one.
If this is a 3rd gen, then none of the Mustang ones will, but the GM one can be made to. The LS1 T-56 takes a little more work in some ways than the LT1 version and a little less in others but can be used if necessary.
Don't know about the TKO-500, never used one.
Several of the board sponsors sell transmission mounts; or you could go to your local speed shop, or Summit or Jeg's, or even AZ or a regular parts store if you want a stock one. Very ordinary item.
Car: 88 Trans Am
Axle/Gears: Posi
ive heard tremec tko's are as easy to install as a t56 but you guys seem to think it is incompatible. i have seem these cars with the tko installed i just need to know where to get a new transmission crossmember or whatever is needed to install it
Car: 87 IROC L98
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
tremec tko will work reguires adapter plate but can still use the stock crossmember you can call fortes perfomance they sell the whole kit
Engine: 4++,350 & 305 CIs
Both of the 2002 ford transmissions will not work without extra "stuff"
the 2 ford 3550s will bolt right up to your stock GM bellhousing. I think the 500 and 600 are of the same design as the 3550s
they even have the holes 4 the stock GM TQ arm.
also they both use GM splined clutch disks
Im not sure if the length of the imput shaft is a problem or not but I think they use the same one.
quick search and here is some info
http://www.5speedtransmissions.com/tr-3550.html
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
