700r4 overdrive shift
Old Aug 1, 2011 | 01:08 AM
nitehawk's Avatar
Car: 83 transam
Axle/Gears: 4:11 posi
is there a way to get a 700r4 to shift into O/D at wide open throttle?
Old Aug 1, 2011 | 06:32 AM
Re: 700r4 overdrive shift
http://www.bulkpart.com/Merchant2/me...ode=4L60-700R4
About the 4th or 5th item from the very bottom of the page
Old Aug 1, 2011 | 02:32 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
It's actually listed twice on that page.
# S74741NCK Throttle Valve Plunger & sleeve kit, 700R4 / 4L60
High performance sleve that allows full throttle upshifts from 3rd to overdrive…. Common vender is Sonnax # 77966-94MK
# A74741B Upshift sleeve , 700R4,
This sleeve allows full throttle 3-4 up-shifts. Upshift sleeve Superior# K015
Old Aug 3, 2011 | 02:46 PM
nitehawk's Avatar
Car: 83 transam
thanks
Old Aug 3, 2011 | 03:52 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
But with the 2 different part #, even though 7474 is in both.....Are they different? Different applications? I think there was a 26-spline version & a 28-spline version (or something like that & dunno if it would make any difference for this) Just different manufacturers?
Old Aug 3, 2011 | 06:00 PM
Sonnax # 77966-94MK
Superior# K015
Iunno; kind of hard to figure that out for sure... I'm thinkin though....
Old Aug 5, 2011 | 12:32 AM
Pro Built Automatics's Avatar
There is a much cheaper way to do this. Two Allen screws and a Allen wrench, about $1.00 for both at the hardware store and you do not have to take off the valve body. Give me your email address and I will send you the instructions. I copy what they do in the Corvettes to get the 3-4 WOT shift. You will be blocking off the 4-3 part throttle passages.
Old Aug 5, 2011 | 12:43 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
im intrested in this. so 700r is 3 speed and overdrive or?? My '4th gear' never really seemed there. can this help me?
Old Aug 26, 2011 | 11:24 AM
nitehawk's Avatar
Car: 83 transam
sounds like your converter isnt locking up right.
Old Sep 8, 2011 | 10:43 AM
cam8's Avatar
hi pro built, id be interested in the wot 4th gear shift mod for the 700r4, email stk591@aol.com thanks cam8
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
