Throw out Bearing Installation
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am installing my new Mcleod throw out bearing right now, and it slips onto the clutch fork with basically no effort as if its not being held onto it good enough. Shouldn't it go on harder than this?
Car: `86 SS / `87 SS
Re: Throw out Bearing Installation
If the spring clip on the back of the fork looks in good shape stands away from for the fork some, I wouldn't worry about it much.
Car: 85 Iroc-Z
The clip looks good, its just that it seems to have a loose fit. Could this cause any problems?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I installed a release bearing today. They fit on the fork very loose. The trans actually holds the bearing in place once it's in. The fork just pushes on the thrust surface of the bearing.
ambainb
Apr 25, 2016 09:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
