WILL PLASTIC DRIVEN GEAR WORK??
Old Aug 9, 2011 | 12:57 PM
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
Hello again,ok so im trying to get my speedo working properly.read the sticky with t5 driven gear info with colors and part numbers.ordered the part number that matched my gear ratio from local dealership.went and picked up part today,its plastic and my original one is metal shaft.will the plastic gear work??read a few threads but couldnt find a yes or no answer>thanks
Old Aug 9, 2011 | 05:33 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: WILL PLASTIC DRIVEN GEAR WORK??
Everythings made of plastic thes days....If it is the correct one it will work. I thought they alway were plastic material.
Old Aug 10, 2011 | 12:09 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 20 and 21 tooth gears with steel shaft are discontinued or really short supply.
You might be able to find 18, 19 or 22 steel shaft gears.
The plastic ones work fine; just make sure the shaft fits the sleeve correctly (the outer seal will need to meet a solid part of the plastic gear shaft.)
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
