Suppossive posi?
Old Sep 16, 2011 | 07:50 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Suppossive posi?
So i bought this a while ago its an 86 irocz which i was told had a posi rear today when i did a burnout only one spun instead of both like a posi should and cant remember if when i first bought it if both did or not could there be something wrong with the rear end or is this just not a posi at all?
Heres a video link to it
http://www.youtube.com/user/Chevrole...6?feature=mhee
Old Sep 16, 2011 | 07:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Suppossive posi?
Take the cover off and have a look inside.
Old Sep 16, 2011 | 09:17 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
What would i be looking for, sorry im a rearend newb
Old Sep 16, 2011 | 09:34 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
NON-posi. Called an "open" differential.
10-bolt Posi carrier.
9-bolt Posi carrier
If you see anything that has a bunch of crap inside a mostly enclosed container in there, it's a posi. If you see something that's just a bunch of gears, like the first pic, it's NOT a posi.
You can always take a pic and post it here.
Old Sep 16, 2011 | 09:35 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Posi carrier.
Thanks ill take a look soon as i can
Old Sep 16, 2011 | 10:05 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Never seen a left wheel only burnout. thought the right was usually the one that fried.
Old Sep 16, 2011 | 10:17 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Thts why im a little confused as you can see at about 55 seconds into the video the right wants to spin but stops
Old Sep 16, 2011 | 11:31 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Before you drop the differential cover be sure to have the new fluid standing by (with posi limited slip additive in case you need it.)Dropping the cover and changing the fluid and gasket is not rocket science by any means but Ive found that having at least a "Chilton's Repair Manual" around is very helpful and really a necessity when working on a car. There about $25.00 at any auto parts store if you don't have one already.
Old Sep 17, 2011 | 06:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You may find useful info below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
