A wierd knock.
Old Sep 23, 2011 | 07:34 PM
grandmasterwayn's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 5-speed
Axle/Gears: Stock
A wierd knock.
Here's my mystery: My !990 RS gives me this little knock when I use the engine to brake, and then again when I accelerate. It sounds like it's coming from the back, so I thought it was the rear axle, or some of the gears in it. I asked the guy at auto zone, and he said it was probably the crush differential. I asked my hanes manual, and it said it might be some loose nuts, and that I should go and tighten them. Any thoughts as to what it might be?
Old Sep 24, 2011 | 07:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: A wierd knock.
I'd remove the tranny mount and see if it's broken.
Old Sep 24, 2011 | 08:55 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: A wierd knock.
I can almost promise you its one of 2 parts or related parts, your torque arm is disconnected or broken somehow and hitting the trans tunnel, or the trans isn't bolted to the x-member, or like above, x-member is broke.
On a less severe and equally likely note, still dealing with the TA and x-member, bushings could be shot, a likely example is that the TA chewed through its bushing and now has some play in it and hits the metal bracket it sits in everytime you accel or decel.
So check the following for breakage/wear/loose/disconnected:
torque arm, torque arm bushing, torque arm bracket(where it mounts at the trans), torque arm bolts at the differential, trans crossmember, trans xmember bolts and bushings.
Old Sep 24, 2011 | 08:56 PM
Engine: 3.8, 3.4
Re: A wierd knock.
If none of that, could be the U joints in the DS.
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
tgp1990
Sep 4, 2015 06:24 AM
andy74
Sep 3, 2015 08:41 AM
Thaney9
Aug 29, 2015 03:16 PM
