TKO 600 in 86 Camaro
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
I have a 86 camaro that I installed a tko600 trans in. I have Ram HD Clutch, Hayes flywheel. The car ran fine with my stock t5 in it with this set up. Than I started doing my TKO swap. I got my TKO 600 kit from AMP Performance its a brand new TKO600 GM 9 piece starter kit which includes the following from AMP Performance. Tremec TKO 600 4618(.82 OD) transmission, short throw shifter, 31 spline slip yoke for 1330 u-joints, needle roller pilot bearing, rubber mount w/hardware, mechanical speedo adapter kit, free synthetic fluid, installation tips sheet and Tremec Hat. I bought a Lakewood Blowproof Bellhousing and the trans is straight up and down not on the slant. Than I got Spohn crossmember for my trans, and got the driveshaft done.
Installed the fluid started the car tried putting it into gear, Couldnt get it into gear. So I bleed the slave cylinder, followed this site instructions (http://www.teamrip.com/how_to_proper...utch_info.html). I tried again to get the car into gear. No Luck still so I adjusted the pivot arm on the bellhousing, unscrewed it half way and restarted the car. It made a squealing noise but once i let my foot off the clutch it want away and i repress the clutch and no noise, tried putting it into gear and with some force it made grinding noise but wont go in. So I unscrewed the Pivot arm bolt all the way out and restarted it and Nothing still. Please help
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: TKO 600 in 86 Camaro
i posted in you for sale thread, didnt see this.
can/could you rotate the output shaft? When i received my tko, is was jammed between gears from shipment, i was advised to put a piece of pipe through the yoke and give it a quick snap/twist to pop is out. then all was well. Maybe thats your issue?
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
First let me start off by saying your probably the TKO specialist on this forum.
Yea that was the first thing i did was make sure it was in Neutral and spin the out put shaft. If I knew this would be this big of a head ache i would of never done the swap
Car: 86 Trans Am
anyway, if thats not it, then is some issues with the clutch setup somewhere. Not the transmissions fault
did you install the TO bearing correctly?
can you verify the slave cylinder is functioning and moving as much as it should be?
is the car running when you are doing this?
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Yes i installed the TO bearing correct. The slave cylinder is moving. The car is running when i try to put it in gear.
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
You mentioned the pivot ball. I remember I had to lengthen the threads of mine in order to get the operation correct. Even with the pivot ball adjusted all the way out I couldn't get the clutch to disengage. Basically I had found a bolt with the correct threading, cut both pieces and welded them together. Gave me much more adjustment.
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Just took the trans out. This is what I found. I noticed the pilot bearing was shread it. But I still want to make sure the throw out bearing is the right one now I got it apart..
Here a few pictures: PHOTOS
Let me know what you think.
Does anyone know how to measure to make sure you got the right throwout bearing.
Car: 86 Trans Am
i find it funny that you already told me you have the TO bearing installed correctly, yet in the pics, its obviously wrong.
as for the trashed pilot, you have have to index the bellhousing to correct that
this is not right, those tabs go under the lip, like the 2nd pic i posted earlier
that is one of, if not the, problem
That would be your problem, right there.
That old pic of mine that 86TA is not the best; here's my later one that I've been using.
Which one does your pic look more like?
That would be why your clutch doesn't work right.
Car: 86 Trans Am
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
SOrry from first picture I couldnt really tell about throwout bearing. NOw my next question is about indexing the bellhousing. HOw do you do that. I Want to make sure I do it correctly.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Old thread i kno but what did you end up doing to solve it? Did you have to index the bellhousing?
Car: 86 Trans Am
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
I did index the bellhousing and the TO bearing was installed wrong. Couldnt of done it with out everyone help. I am also renting out the Aligment tool
How do you like your trans and rear gear combination now that it works?......Do you use a mechanical speedometer? Is the shifter in a good location? Sorry about all the questions.....just interested.
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
I like it. It works good together.Yes I use mech speedo. The kit I bought came with adapter so the speedo is right with the tire and gear combo. Shifter is in good location all I had to do was do a little trimming work to the center console but you cant tell.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
LT1Formula
Nov 16, 2015 01:13 PM
86IROC112
Aug 17, 2015 02:00 PM
