700r4 lockup question
Old Oct 2, 2011 | 03:41 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Ok so I now have my 383 HSR being built and I was looking at the new Holley HP efi http://www.holley.com/550-601.asp to control everything when I realized that I dont think the HP controls TC lockup. Now im stuck on what to do because I dont have any of the OEM ecm or harness as I sold everything for cash for build parts. I also checked out the Dominator from Holley http://www.holley.com/554-114.asp and it states that it has TC control but it also cost two hundred more and without the harness/sensors included, and it looks alittle to much for what I need. So my question is do I need lockup? can I just but a TC that is nonlockup? or is there something out there that I can use to control the lockup outside of using a ecu? Any help would be great.
Old Oct 2, 2011 | 05:49 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 700r4 lockup question
look in the carburetor section at the top under tcc control.
Old Oct 3, 2011 | 06:55 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Great link, Thanks. I was looking at this onehttp://www.summitracing.com/parts/BMM-70244/ and just wanted to know is this something that I have to keep playing with and tweek everyother day or can i set it one time and be done with it?
Old Oct 3, 2011 | 07:01 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
At what point when im driving do I know when to control the lockup? Is it something I will feel in the car when driving or do I just hope its doing its job when I set it? Ill be running a 3000 stall if it matters.
Old Oct 8, 2011 | 08:02 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by robbyk85
So my question is do I need lockup?.
85 T700 needs lockup because you only get full fluid flow to trans cooler when lockup engaged.
or is there something out there that I can use to control the lockup outside of using a ecu? At what point when im driving do I know when to control the lockup? .
Can do mods inside trans to give auto lockup as soon as trans goes into 4th gear.
Nothing to think about when driving
http://forums.corvetteforum.com/1565197629-post12.html
http://purplesagetradingpost.com/sum...o/700R4p2.html
Old Oct 8, 2011 | 08:50 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
You will be able to feel the converter go into lockup so if its not working youll know .
Old Oct 9, 2011 | 05:27 AM
Pro Built Automatics's Avatar
Go with the Painless setup. It will offer 3rd & 4th lockup at part throttle and unlocks when going to WOT. It is very complete and comes with the brake release setup. It is trouble free.
Eric-86sc
Aug 24, 2015 09:01 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
