700R4 cable/electronic speedometer
Old Oct 2, 2011 | 04:43 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hello guys. I need some quick help. Im gonna buy a used 700R4 tomorrow for my 86 IROC (cable speedometer cable). But the tranny is a electronic speedometer type. So my question is, could I convert the electronic tranny to accept the cable speedometer cable?
Old Oct 2, 2011 | 05:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 700R4 cable/electronic speedometer
Yes. Pull the electric and insert the cable housing and gear. Hopefully, the drive gear will be the same or you'll have to swap yours in to make the speedo read correctly.
JamesC
Old Oct 2, 2011 | 05:26 PM
JamesC, hows it going man. So thats it? Remove the tail shaft housing, count the teeth on the gear and swap out the electric housing gear thing? Sounds almost too easy. So as long as the tranny is a TCC, I should have absolutely no problems with the swap right?
Old Oct 3, 2011 | 12:09 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yep. 92-down TCC connector should be the same; '93 was different.
Old Oct 3, 2011 | 12:20 AM
Right on man. Thanks for the info.
Old Oct 3, 2011 | 06:15 AM
JamesC's Avatar
You may be able to count the teeth through the 'hole' where the cable housing inserts, thus saving yourself some time if the count in the new trans is the same as your old.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
6998poncho
Sep 25, 2015 02:56 PM
