rear end swap, got some questions!
Old Oct 12, 2011 | 12:48 PM
alexquade's Avatar
Car: 1992 RS
OKAY! i have a 1992 rs, with 2.73 gears in the rear. well, my buddy has a 1991 s10 with 3.73 gears that i'd like to put in my car. i'm almost certain the rear end won't be bolt in, BUT can i just rip those gears out and put them in my rear end?? thanks!
Old Oct 12, 2011 | 02:37 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: rear end swap, got some questions!
You would have to swap the entire carrier over. The 2.73 would have a series 2 carrier if stock and the s10 would have a series 3 carrier and the gears dont interchange between each other.
Old Oct 12, 2011 | 02:46 PM
alexquade's Avatar
Car: 1992 RS
Thanks! sorry, not to vehicle savy, BUT! define carrier... the entire axle??
Old Oct 12, 2011 | 02:58 PM
Carrier = the thing the ring gear bolts to
Note how the one on the left (2 series) holds the ring gear about .400" farther away from the pinion CL than the 3 series on the right, since as the ratio DECREASES, the pinion size must INCREASE.
Old Oct 12, 2011 | 03:09 PM
alexquade's Avatar
Car: 1992 RS
So thats all i have to swap? Basically all the guts in the s10s rear end into the one on my camaro? Right?
Old Oct 12, 2011 | 03:21 PM
Right.
Except that the S-10 carrier is probably a Gov-Lock aka Grenade-Lock or Gov-Bomb, which is something to be avoided at all costs.
And, you ay have to reset the backlash, which is done by changing the shims on the carrier bearings. Will CERTAINLY need to be done if you use the ones out of the other housing; might be OK if you re-use your existing ones; but there's no guarantee of that.
Old Oct 12, 2011 | 09:42 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Plus swapping the pinion gear is the fun part. Setting the pinion depth correctly is crucial. With the one-time-use crush sleeve, you have to get it right the first time. The carrier setup (backlash and bearing preload) with the side shims is no big deal, you can change it till the cows come home till you get it right.
Old Oct 12, 2011 | 10:18 PM
alexquade's Avatar
Car: 1992 RS
Sounds like i may be in over my head for my experience. It may hafta wait a lil while. Haha. Thanks a bunch for ur quick responses!
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
