tranny cooling line removal at radiator
Old Oct 17, 2011 | 01:16 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Does anyone know the size of line wrench that Im gonna need to remove the tranny lines from the radiator? Its a metric, but i dont wanna go to Autozone and buy all the line wrenches only to break them out of the packaging. Thanks
Old Oct 17, 2011 | 01:28 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: tranny cooling line removal at radiator
check it with a wrench before you go to the store. i think its 13mm, not positive though. i can do a quick check later, if need be.
Old Oct 17, 2011 | 05:25 AM
Yup. That would be cool. Thanks redneckjoe. I don't even had wreches.
Old Oct 17, 2011 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had to remove the trans lines in my Jeep recently. I soaked the fitting for several days with PBBlaster, then used a regular wrench (didn't have the appropriate-sized line wrench, which, of course, would be the best bet) and gave it a couple of love taps. Came off without issue.
JamesC
Old Oct 17, 2011 | 08:28 AM
Right on JamesC time to get some penetrating oil. Thank you.
Old Oct 17, 2011 | 08:34 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
just checked. my 87 uses 13mm wrench size for the tranny cooler lines.
Old Oct 17, 2011 | 03:47 PM
I feel bad calling you redneckjoe. Just doesnt sound right. But any how, thanks for going out of your way to get me the wrench size. You are a good person. Again, thanks man.
Old Oct 17, 2011 | 07:31 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
no problem 86. joe is cool. i got the nickname years ago cause i do welding & car repairs out of the house. there always seems to be crap all over my yard. idk,...somehow the name stuck. lol. so did you get your lines loose?
Old Oct 17, 2011 | 07:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1/2" is close enough to 13mm to use. I don't think transmission lines are metric. They're 5/16" steel lines with flare nuts similar to brake lines.
Old Oct 17, 2011 | 08:35 PM
Hi Joe. Not yet man. I'm a full time college student. I've been out of home since 3:15 am. And now its 6:30 pm. I won't be home until 10:30 tonight. I had spoken to a fellow member how owns his own shop. His name is Chevy8588. He told me its metric but he couldn't recall the size.
Old Oct 17, 2011 | 08:49 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
theyre both very close in size. the 13mm will work.
Old Oct 17, 2011 | 09:18 PM
13 it is. Thanks guys. I'm gonna replace my stock radiator with a "Champion Radiator, model CC951".
Old Jan 12, 2012 | 10:49 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i use metric "crows foot" line wrenches they are the tool to use here it keeps you from rounding off the shoulders on the fitting
Old Jan 12, 2012 | 11:46 PM
I found the right wrench for the job. Unfortunately the edges of the bolt where rounded. So I used my vice grips.
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
