lockup and cruise problems
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
can anyone help with this...its an 87 iroc with a 700 r4 its not locking the torque convertor up and my cruise isnt working. i checked the plug on the brake pedal and it checks out fine. is there something else that would keep these things from working? any help would be appreciated!
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Re: lockup and cruise problems
well went to the yard and got a couple cruise modules hope that will fix it not had time to check them out yet. also got pedals and all the hydraulics for a 5 or speed swap later.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
cable is good Aaron_SK...gonna mess with it 2mar some i cldnt find a speed buffer any where i thought the 87 didnt have it. i picked up 3 cc modules an 2 of which are the same as wat i have so i'm hoping thats the problem. also gonna check the shift cable cause its hard manually shift all the way down to 1st gear.
On your '87 Camaro the VSS buffer is on the back of the gauge cluster.
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
yea its the yellow box behind the speedo right. im gonna mess wit it today after i clean the battery cables on my gto or put new battery in it, if its not one thing its another. thanx for all the suggestions guys it is appreciated!
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
ok so here is what i found it is locking up but still no cc the wiper switch is broke so that explains the cc not working. also the factory tach is way wrong i hocked up two other aftermarket tach's to confirm it was wrong its fast by 400 rpm. the po had a hot wire going from one of the relays to the coil so i guess they screwed the tach up, a replacement should be an easy find at the local yard but may be a day or two before i have time to get it. there sure are alot of bugs to work out of one if it sits dormant for 4/5 years.
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
ok guys i messed with it all evening i changed the cc module and got my shifter fixed. took it for a ride and still no lockup in overdrive. its taching bout 2 grand at 60 mph and i keep waiting on it to lockup. the only thing i have not changed is the vss, will any vss work as long as it is 86 up? my speedo is a 145 will a vss work off a 110 speedo, cause i have a couple of those laying arround from the junk yard trips. any help would be greatly appreciated.
Ghettobird52
Jul 5, 2024 11:18 PM
someone972
Aug 30, 2015 12:52 AM
