2.73 to 3.23?
Old Nov 14, 2011 | 10:46 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
2.73 to 3.23?
Just wondering what you all have experienced with a swap like this. I have 273's now and was wondering if i went to a 323 rear end, then am i just looking at better "off the line" power or will i gain everywhere else too?
Old Nov 14, 2011 | 11:10 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: 2.73 to 3.23?
If you are gonna do the switch or even put time into this. Do it right the first time and go 3.42s to max results.
Old Nov 19, 2011 | 12:38 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Re: 2.73 to 3.23?
I went from 2.73 to 3.42 in my 87 305 carb and 700r. With that there is a little bit more roar on the freeway, but not much. Your 350 with bolt ons has probably double or more power then my stock 305. You can easily handle the 3.42's, and there just as easy to find as the 3.23's
Old Nov 19, 2011 | 01:21 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
Re: 2.73 to 3.23?
i have a 305 tbi puting down 202 hp and 268 tq i went from 2.73 open to a 3.42 posi made a big difference
Old Nov 19, 2011 | 07:06 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: 2.73 to 3.23?
What ever you decide, you will need to replace the carrier with a 3 series carrier. https://www.thirdgen.org/forums/tran...-10-bolts.html
Old Nov 19, 2011 | 08:04 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: 2.73 to 3.23?
They do make 3.42 gear sets for 2 series carriers. I also saw a ring gear spacer to enable you to use 3 series gears on a 2 series carrier.
Old Nov 19, 2011 | 09:43 PM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Axle/Gears: 3.42 w/posi & disc brake
Re: 2.73 to 3.23?
Ill second this... I just swapped a 3.42 w/ disc brakes from a 2002 v6 fourth gen into my 91... Everything bolted up perfect... even the brakes bolted up... I picked the rear end up from U-pick junkyard for $138 and paid $300 for the installation of a truetrac and new axle bearings...
For what its worth, I am definetly happy with the results!
Old Nov 19, 2011 | 09:59 PM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Re: 2.73 to 3.23?
http://www.youtube.com/watch?v=aT5BGbePU_k
Here, u can see for ur self...
KO1
16
Oct 15, 2015 05:00 PM
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
