9 bolt rear removal
Old Nov 17, 2011 | 04:32 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
9 bolt rear removal
Hey everyone I'm in the Process of removing my 9 bolt rear end outta my 89 Gta so far I got the stock pan hard bar out an also the track brace bar down. Tomorrow looking into taking the calipers an rotors off what else do I need to do to remove it
Old Nov 17, 2011 | 04:54 PM
Twin_Turbo's Avatar
Re: 9 bolt rear removal
You don't have to remove the calipers or rotors, only the soft line to the rear firewall, remove, the parking brake cables, the 2 shocks, springs and the bolts from the trailing arms...that's all.
Old Nov 18, 2011 | 09:55 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
twin pretty much covered it, but dont forget the driveshaft u-joint straps too! sway bar end links to the body will have to be removed (but probably will brake, dont worry, they're cheap to replace) as well
Old Nov 18, 2011 | 12:27 PM
Twin_Turbo's Avatar
Lol forgot those
Old Nov 18, 2011 | 05:00 PM
Engine: LR4 4.8
Is there a special way to remove the springs with out doing it with a spring comPressor also I was looking at a to get a new pan hard bar an track brace bar but no one sells a aftermarket track brace bar it's the bar that's above the pan hard that bolts into the frame by 3 bolts on the drivers side quarter panel
Old Nov 18, 2011 | 08:24 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
rear springs will fall out. no need 4 a compressor.
Old Nov 21, 2011 | 06:25 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
stick with the stock track bar brace, no need to upgrade. also, there have been some fit issues with certain "upgrades". upgraded panhard's not a bad idea if your bushings are shot in the factory piece; go with an adjustable one if you plan on lowering at any point in the future.
as for springs, TTop350 covered that - no compressor needed. Put the jack under that side and lower the axle slowly after removing the shock and the spring should fall right out.
Old Nov 21, 2011 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by soarestransam
also I was looking at a to get a new pan hard bar an track brace bar but no one sells a aftermarket track brace bar...
Granatelli does or did:
https://www.thirdgen.org/forums/afte...r-panhard.html
I figure the situation in this manner: If the piece was a worthwhile upgrade, companies such as Spohn, UMI, and BMR would have already jumped on the bandwagon.
JamesC
Old Nov 21, 2011 | 08:16 PM
Engine: LR4 4.8
Yea this is true Ive been on plenty of aftermarket web sites to try an find the track brace bar but no one does it so I'll just stick with the stock one for the pan hard bar an rear lower control arms I saw a link on here for founders performance ones that are also adjustable how would u guys rate these of a scale of one to ten on performance an cost wise
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
