88 TA rear end?
Old Nov 19, 2011 | 03:12 PM
sick84's Avatar
88 TA rear end?
Looking at getting a 88 TA rear for my 88 camaro. This should be a direct bolt in right? Claims to have a 3.23:1 posi unit in it. Is it worth 300 bucks.
Rear has disc brakes and aluminum calipers
Old Nov 20, 2011 | 07:06 AM
bigtoyz's Avatar
Car: 1988 IROC
Engine: 350 w/650cfm carb
Axle/Gears: 3.23 posi
Re: 88 TA rear end?
From what I have seen locally (SE Georgia) 300 bucks is about right provided you dont have to completely rebuild it, and, yes, it should bolt right in.
Old Nov 20, 2011 | 07:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 88 TA rear end?
If the rotors are 11.7" accompanied by alum PBR calipers, the brakes have either been swapped on the car or the rear isn't from an 88 (should be 89+).
Verify whether the rear is a 9- or 10-bolt. You'll need a first design 1LE combination valve for best braking performance, parking brake cables, and speedo drive and/or driven gears to make the speedo function correctly.
JamesC
Old Nov 20, 2011 | 02:24 PM
sick84's Avatar
Re: 88 TA rear end?
JamesC
It is a 10 bolt rear and it does have the PBR calipers. Im not sure about the rotor size I can measure and post later. I also plan to put Autometer gauges in sooner or later. Any tips on how to clean it up for paint? Are the drum brake axles the same as the disc? the studs on the axles look awful short. Ill try to post some pics later
Old Nov 20, 2011 | 03:07 PM
JamesC's Avatar
Re: 88 TA rear end?
You'll find the answer in the following link, along with other info that you may find interesting:
https://www.thirdgen.org/forums/tran...-10-bolts.html
EDIT: BTW, if the rear is a 10-bolt with PBR's, it'll be 90+.
JamesC
Old Nov 22, 2011 | 12:41 PM
sick84's Avatar
Re: 88 TA rear end?
If Im not mistaken the mount for the locating bar on my stock rear is on the right spring pocket on the differential. on this TA rear its on the left? Correct me if Im wrong? Im out of state and cant remember for sure if my mount is on the right side or not
Old Nov 22, 2011 | 12:49 PM
JamesC's Avatar
Re: 88 TA rear end?
There're all the same.
JamesC
Old Dec 3, 2011 | 01:03 PM
sick84's Avatar
Re: 88 TA rear end?
Is there anyway I can get a aftermarket combo valve and use that? I plan on running all new brake lines etc. while I'm under the car. Thanks for the help
Old Dec 3, 2011 | 03:01 PM
JamesC's Avatar
Re: 88 TA rear end?
Sure, though you may have to do some plumbing.
JamesC
Old Dec 3, 2011 | 03:13 PM
sick84's Avatar
Re: 88 TA rear end?
JamesC
what do you mean by plumbing? Also with the parking brake, I don't have to have that hooked up right? I planned on removing the handle from the interior as I have plans for that spot.
Old Dec 3, 2011 | 03:24 PM
JamesC's Avatar
Re: 88 TA rear end?
The after market piece won't be a bolt-in. You may have to bend and flare lines--for me personally, the correct OE valve would be simpler. At any rate, the after market is common enough. A search should turn up a ton of info.
No, unless you have to pass an inspection. If you're running a T-5, you'll miss the parking brake in the long run.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
