Will a T56 leak fluid when drive shaft removed?
Old Nov 19, 2011 | 09:47 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
I'm in the midldle of a T56 swap and have got the T56 mounted to the engine. I don't have the drive shaft or torque arm installed. At this point I would like to fill the trans with fluid and run the engine up to check clutch operation and see if it shifts gears with the motor running.
Is it ok to fill it up with fluid or will it all come pouring out the rear?
Old Nov 19, 2011 | 09:53 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Will a T56 leak fluid when drive shaft removed?
it will not leak
Old Nov 20, 2011 | 11:14 AM
oamhmad's Avatar
Car: 84 Trans AM
Well I tried to do this and it most certainly does come pouring out the rear.
You owe me half a quart of ATF.
Old Nov 20, 2011 | 11:52 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
as long as the trans is level the leakage can be minimized, even better if the tailshaft is lifted a small bit.
But just like an automatic, the output shaft will leak like a sieve if you pull the yoke out. Especially if the tailshaft dips down.
Old Nov 20, 2011 | 12:15 PM
oamhmad's Avatar
Car: 84 Trans AM
That explains it. I had the yoke and drive shaft pulled out and no tranny mount installed so the tail shaft was pointing down a bit.
Old Nov 20, 2011 | 12:36 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah if the trans is pointed down bets are off.
Mine didn't leak when I put my aluminum 'shaft on it.
Old Nov 20, 2011 | 12:59 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A bolt-on yoke would be the right way to do it.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
