help
Old Dec 6, 2011 | 09:58 AM
dowell's Avatar
help
have a 1973 mustang i put new motormounts in. The engine fan now hits the shroud. called the store where i bought them to see if there are different mounts, they say the only question the book asks is if its a coupe or convertible. my question is are these mounts diferent?
Old Dec 6, 2011 | 10:00 AM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: help
o.O
Old Dec 6, 2011 | 10:09 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: help
There are a lot of sites where you can look up parts by application and tell if they're different part numbers at least.
And your auto parts professional could answer that question for you by looking up the convertible too.
Old Dec 6, 2011 | 10:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: help
Originally Posted by dowell
have a 1973 mustang....
dowell, you should know that this site is dedicated to 82-92 F-Bodies (Camaros and Birds). A web search should provide you with a ton of sites directed at Mustang owners.
Best of luck on your project.
JamesC
Old Dec 6, 2011 | 11:36 AM
dowell's Avatar
Re: help
well then camaros and birds should not be prejudiced to some one who has done a random web search in need of help and your web site did not specify chevy at the search thanks for your not needed freakin comments very unprofesional for a so called help website thanks again for not helping freakin jerk
Old Dec 6, 2011 | 01:55 PM
jmd's Avatar
jmd
Re: help
lol
Old Dec 6, 2011 | 05:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: help
You need to take a rage dump man, the only person here being disrespectful is you. You need to calm down, you are making yourself look like an *******.
Anyway, you installed new motor mounts. I assume these had rubber inserts. These parts sag overtime, lowering the engine and changing the driveline angle. The new mounts raised the engine and again changed the driveline angle, possibly causing this rubbing issue. Have you changed the trans mount? If you have not, I would try that and see if by raising the back of the trans a little with.a new mount, this issue goes away.
Old Dec 6, 2011 | 07:03 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: help
try www.fordbarn.com
