Why does my trans shift at 6200 RPM?
Old Dec 16, 2011 | 09:17 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I've recently purchased an '85 IROC. 40K miles, LB9/700R4/3.42. I haven't driven it much yet, just around the neighborhood. Trans seems to shift fine, except at WOT, it shifts from 1-2 at 6200 RPM. Should be more like 5500. What do we think?
Old Dec 17, 2011 | 08:54 AM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Why does my trans shift at 6200 RPM?
BTW, I've already adjusted the TV cable. The car spent alot of years just sitting, wonder if it has a 'sticky' valve or something...
Old Dec 17, 2011 | 05:47 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
lots of third gen tachs read high.
Old Dec 17, 2011 | 07:22 PM
chazman's Avatar
Axle/Gears: BW 3.45
I know that is true of the '90-'92 electronic tachs, but I've never heard of that on the earlier cars.
Old Dec 25, 2011 | 11:41 PM
chazman's Avatar
Axle/Gears: BW 3.45
It looks like it was my TV cable. I had to fiddle with it a little before it would adjust properly. The 1-2 WOT shift happens at 5500, just like it's supposed to.
Old Dec 26, 2011 | 12:43 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
the old tachs are off I have put two different tach In my car and both read 6500 rpm shifts but looking at my snap on scanner its saying 5600 rpm
Old Dec 26, 2011 | 02:27 AM
robvano's Avatar
Car: 72 Chevelle
Engine: 468
Transmission: Muncie
Axle/Gears: 355
I'd make sure the tranny pressures are within the correct range. The TV adjustment is critical on The 700r4s. you can damage it pretty quick.
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
