Will 6 speed Hydra-Matic 6L80 fit?
Old Jan 10, 2012 | 09:04 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Just out of curiosity, because i've seen some of these go on EBAY with a LS3 from the new SS camaros.. Does a Hydra-Matic 6L80 six-speed automatic transmission fit directly into third gens, physically I mean.. Has it ever been tried? I know it would be longer than my 700R4, but I could always get a shorter driveshaft... Just curious!
Old Jan 10, 2012 | 02:52 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Will 6 speed Hydra-Matic 6L80 fit?
the 6l80 will not fit without modifying the trans tunnel, its bigger than the 4l80e and those just barely fit for some. then you have to deal with the torque arm issue (not too hard, just have to get something crossmember mounted). then there's the custom crossmember you need, nothing direct swap for 3rd gens. THEN you have the TCM to deal with, nothing stand alone I know of yet.
TCI does make a 6-speed setup that may work (apparently they use a 4l80e case or similar?), but they're around $8500-9000......
Old Jan 10, 2012 | 03:51 PM
Ouch.. I think i'll stick with the 700R4 for now lmao.. Thnx for the info!
deracer
Apr 11, 2016 12:04 AM
Keith5
Aug 27, 2015 04:37 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
InfinityShade
Aug 22, 2015 08:00 PM
IBrockZ
Aug 20, 2015 12:20 PM
