Filled differential through vent hole?
Old Jan 20, 2012 | 10:47 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
So my filler hole was rusted to hell and I ended up putting 2quarts of gear oil through the top vent hole.
The seal that meets the driveshaft is leaking so I figured the car was due for some fluid.
I removed this and added fluid through it
did I mess up? Lol i know it's a little late just figured I'd ask if I'll see any problems.
Old Jan 20, 2012 | 11:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Filled differential through vent hole?
Im guessing you drained the old fluid 1st ?? How about limited slip additive ? do you need it?
Old Jan 21, 2012 | 12:50 AM
Car: 1986 Iroc-Z
Engine: 355
Don't have a posi so i didn't use any additive. Nope didn't drain it but I know the leak has been around for about 6 months now, so it def needed it.
Old Jan 21, 2012 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Info on replacing the pinion seal below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jan 21, 2012 | 06:46 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
So you just guessed at how much to add?
Old Jan 21, 2012 | 06:54 AM
JamesC's Avatar
With nearly two quarts added to what might have been in there, he's probably overfilled.
JamesC
Old Jan 21, 2012 | 06:57 AM
Car: GTA
JamesC
Yeah. Unless it was a real bad leak & puddling the fluid or to the point of getting gear whine? It is likely overfilled now.
Old Jan 21, 2012 | 07:55 AM
TTOP350's Avatar
Waaaaaaay over filled!!!!!!!!
Old Jan 21, 2012 | 09:48 AM
Car: 1986 Iroc-Z
Engine: 355
Thanks for the reply guys. Yeah I wouldn't doubt it's overfilled.
Should I go ahead and drain some of it or leave it and let it leak out?
I'm assuming ovefilling would add pressure to the seals, but since I already have a seal that's leaking would that still apply?
Old Jan 21, 2012 | 10:00 AM
JamesC's Avatar
I'd make an effort to remove the fill plug (which you need to do anyway). If overfilling has occurred, fluid will dribble out to the proper level.
JamesC
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
dbrochard
Jan 28, 2016 08:42 AM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
dbrochard
Sep 19, 2015 08:13 PM
