To change the fluid out or leave it age old question 700r4
Old Feb 14, 2012 | 10:49 PM
camarocasanova's Avatar
So after purchasing my iroc I have found it has dirty brown slightly burned fluid in the 700r. I am torn-the pan on the outside looks real clean but I am afraid it has never been opened up on a car that is around 100k. I have heard the horror stories of changing out the fluid. It shifts ok right now no slipping that I am aware of, but the fixer in me says change it all out. What's been your experiences?
Old Feb 14, 2012 | 11:44 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: To change the fluid out or leave it age old question 700r4
change it, if it starts slipping fix the trans, thats the most correct way to do it.
Old Feb 15, 2012 | 05:44 PM
If the fluid is brown, the trans is smoked. Whether you "notice" it or not, it's slipping, or has been, some time or other. Or, overlapping too much. Either way, it is not long for the world.
Doesn't matter whether you change it now or later; you're looking at some trans work in the immediate future.
Might as well save it for after you fix it, so you won't just burn another fill of fluid up too.
Old Feb 15, 2012 | 07:51 PM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
I say change it and dump a quart of lucas in it. I have seen slipping trannys get another year or two before thay have to go in.
Old Feb 19, 2012 | 08:31 PM
Changed fluid and filter today....ugly colored fluid and some clutch dust in pan but I have seen much worse...certainly no metal though. I am thinking the fluid might have looked bad because the car did sit for awhile before I got it. I put a drain plug in the pan so I will run it a bit and then dump some more out till its blood red again
Old Feb 19, 2012 | 11:01 PM
Seafarer12's Avatar
Glad everything looked good. Every change will cut it in half so 2 changed will give you 3/4 new fluid. Are you running Dexron 3 or 6? I am working on getting my stuff swapped over to 6.
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
