Look what I picked up yesterday!
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Finally got my hands a better rear for my car. Stole it for $400 bucks off a guy locally.
Came off a 1999 LS1 Camaro with ~90K miles, GM 7.5 10 Bolt, Torsen Positive traction differential, 4:10 gears, PBR Brakes and Sway bar. Even has the ABS. Came with the eBrake lines too. Just have to buy a disk/disk proportional valve.
Going to spend a week cleaning it up, painting it, replacing brake pads and such. Then spend a weekend getting it installed.
That'll be a couples weeks though, have my hands full with body work at the moment.
Re: Look what I picked up yesterday!
I didn't even have to pick it up, he dropped it off at my house for me, because he was going pass my area for his sons baseball game!
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
are 4th gen rearends a direct fit?Please say yes!!!
Car: 1990 camaro RS
Engine: 305 TBI
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Nice find! I may look into this upgrade for my build. Either this or moser. Hmmmmmm
Car: 1987 Trans Am
Engine: LQ9/L92
bear in mind, this is still a stock 10 bolt, so no stronger than any of the 3rd gen 10 bolts with the 28 spline axles. they are a nice upgrade for guys who have relatively stock motors but stuck without posi or disc brakes, but a built setup can kill them.
Indeed. Building is always going to be better. But exponentially more expensive. :/
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
building a ten-bold really wont make it any stronger either... just buy you a little bit more time. You need to upgrade to a rear with larger diameter ring gear to see and real strength improvements
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Axle/Gears: 273?277
dont know what a prop valve is,But I got a iroc with stock 5.7 and if the rearend which is a disk type,gose out there are alot more 4th gens out there right now than 3rd.also got a 86 bird with drum might like to have disk on if I come across a parts car.
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
I'm one of those people. I got a 3.23 Limited Slip out of a 1994 Camaro with Disc Brakes (Of Course). I love it! Never changed the Combo Valve. Braking is great!
Before you take out your old rear end, make sure that "T" connector on the differential for your brakes has the same threads as the one on the car. On the 82-84 Diffs, they may have a different size. Mine did and none of the part houses had that in stock. All of them said it was a week wait. I finally brought the old one to a place that makes the connector custom and that worked. you also have to get the E-Brake cables from a 90-92 Camaro. The other ones are too short. Again, those are special order from the parts house. I recommend that you have all of those parts BEFORE you begin.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I am glad James convinced me to get the J65 valve for my setup. Braking is night and day from the old valve. Night and day.
I'd never recommend not replacing it after seeing the difference myself.
These are after I got it all cleaned up right before it went under the car!
Only got to take it down the road for about 5mins. It's getting some paint work done today so it's been getting prep'd for that. Huge difference in acceleration! Love it!
[MN] S&W 8 point rollcage
FueledSoul
Sep 30, 2015 09:18 PM
raymondandretti
Sep 27, 2015 06:43 PM
FueledSoul
Sep 26, 2015 12:00 PM
