Hawks t-56 conversion kit or piece everything together myself? Thoughts of the kit?
Old Feb 18, 2012 | 02:14 PM
thegooseman's Avatar
Car: 1992 RS
I have been thinking about doing a t-56 conversion for a while now, and seeing the Hawks kit appears it would make it a lot easier to do. Talking with my buddies, they believe it is over priced, and believe I should piece everything together myself.
What do you guys think? Is the kit worth it? Has anyone here used it?
Old Feb 18, 2012 | 02:36 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Re: Hawks t-56 conversion kit or piece everything together myself? Thoughts of the ki
Its not too bad of a price if you dont have time to peice it all together, honestly i was expecting it would of been $2500. Probably not a good deal if you plan on buying a new clutch, flywheel and hydraulics.
I'd be a bit sceptical as to what cross member they inculde (to fit a 3rd gen) though, it says 'used' and I'm pretty sure the 4th gen one doesnt fit (frame rails are different angles) and the 3rd gen T-5 and 700R4 dont fit a T-56.
Old Feb 18, 2012 | 02:46 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It is not a cheap swap. But EVERYTHING hawks is overpriced. I'd piecemeal it together over time. You'll save money. Go with a factory clutch too.
Old Feb 18, 2012 | 04:35 PM
Car: 1992 RS
Honestly the price didn't seem to bad to me because part of what your paying for is the convenience. What I worry about is how used are all the parts?
Old Feb 18, 2012 | 05:44 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I have a crossmember for sale its from hawks spohn I think going auto again so I dont need it anymore
Old Feb 22, 2012 | 12:23 PM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
get everything by pieces but if ur going to buy the conversion kit the only parts i would probably change would be the master/slave cylinder and the clutch disk. im in the process of getting things by pieces so these are the prices i've paid so far:
$55 pedal assembly
$25 cross member
$100 bellhousing w/ bolts and slave spacer
$85 for speedo signal converter.
so $265 spent so far im guessing $900-$1300 for the t56 (some people will only sell their tranny if you buy it as a bundle ie flywheel,clutch etc)
so at the most i feel like the swap will be coming at 1600-1800 with good parts. hawks is $2,200 plus $50 for putting it in a box plus the cost of shipping plus any replacement of their "USED" parts. so its starts adding fast!
ps actually in the ltx and lsx forums Roostmeyer is selling a pretty good bundle
Jorlain
Aug 24, 2022 05:11 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Mickeyruder
Sep 2, 2015 02:45 PM
cRoe4
Aug 7, 2015 08:46 PM
drathaar907
Aug 6, 2015 04:20 PM
