What type of transmission
Car: 91 RS
Engine: 305 TBI
Transmission: 700R4 shift kit vette servo
Axle/Gears: 3.73 Eaton Posi
How do you know which type of transmission you have. I have a 91 rd 305tbi. I've read some have the 4l60 and some came with the 4l60e.
Can someone explain the difference to me and which one my car came with.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 91 RS
Engine: 305 TBI
Re: What type of transmission
is it the vacuum lock up or electronic lock up ??
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
If it's stock you have the 700R4. Provided it is the automatic.
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
I think 4th gens had 4l60s in them. never heard of one in a third gen. unless its been swapped. 700r4s have a three wire,four terminal plug that is on the driver side for the converter lockup. not familiar with 4l60s
Car: check
Engine: check
Transmission: check
The 4L60E (note the E) is the electronic version of the 4L60 (note no E) transmission. The E version was never factory in our 3rd gens.
The 4L60 transmission is the same exact transmission as the 700R4.
GM changed the naming convention in 1990 or '91. As it stands the '92 3rd gen factory service manual refers to the automatic trans as the 4L60 transmission, RPO code MD8.
The reason for the naming change is to better reflect the physical attributes of the transmission.
4L60:
4 - four forward speeds
L - longitudinal layout (T for transverse, FWD)
60 - torque rating, metric, no sure of the units used
E - electronically controlled
RBob.
4L60:
RBob.
Car: check
Engine: check
Transmission: check
Going to be a good day: I learned something today that I was unaware of yesterday. I don't have a 90 shop manual but the 91 shows the 4L60.
JamesC
JamesC
Car: 91 RS
Engine: 305 TBI
That's why I asked because I have the 91 shop manual and it says 4L60, but everyone says 700R4. How difficult is it to pull and rebuild the transmission I'm a complete noob at transmissions so if it's best left for professionals I will pay to have it done, but if a guy with some mechanical knowledge can accomplish rebuilding it then I'm all in!!
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Hello, Michael
Sep 11, 2015 01:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
