Reinstalled gas tank and need help
Old Mar 9, 2012 | 07:46 AM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Like stated, I reinstalled my gas tank and put the suspension back together. But when I start letting the jack down, the rearend starts rotating downward and the springs looks as if they'll fall out if I go all the way. Did I miss something or is this normal? Thanks.
Old Mar 9, 2012 | 08:30 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: Reinstalled gas tank and need help
If your shocks are installed, your springs wont come out.
Old Mar 9, 2012 | 08:46 AM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Ok...thanks lol
Old Mar 9, 2012 | 08:50 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Did you get the springs back into the donuts the correct way? You may also have to turn the spring a little to get it to sit correctly on the axle.
Old Mar 9, 2012 | 04:34 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Cool I will double check that. Thanks guys.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
BOOT77
Sep 5, 2015 03:55 PM
