T-56 swap master cylinder issues
Old Mar 12, 2012 | 04:05 PM
Holmes's Avatar
Car: 1991 Camaro Rs/Z28 clone
Engine: 5.3LSX
Axle/Gears: DTS 12 Bolt 4.10
Hey there, so I'm in the process of hooking up the hydraulics and the it seems like the master cylinder rod is too short to hook up to the clutch pedal. I've looked at the swap threads and haven't seen much about this, so not sure whats up. Was looking at threading it to make it adjustable but I've heard issues about that. Anyone know about this? I was thinking about just buying a new stock replacment since it is a used part to see if that is an issue.
Old Mar 12, 2012 | 04:31 PM
Mudluver27's Avatar
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
Re: T-56 swap master cylinder issues
Should not be too short if the master was installed in the correct place. Pics would help. I just did my swap and learned ALOT the hard way.
Old Mar 12, 2012 | 06:41 PM
Holmes's Avatar
Engine: 5.3LSX
OK, I'll see if I can get pics soon. Car is currently locked up in my mechanics shop for the night. Once I can get back out there to work on it this week I'll get some pics. Would you happen to have any pics of your clutch/master cylinder setup for reference? If not, no worries.
Old Mar 12, 2012 | 06:45 PM
Mudluver27's Avatar
Car: 1988 Firebird
Old Mar 12, 2012 | 06:49 PM
Mudluver27's Avatar
Car: 1988 Firebird
Terrible picture but the first time I installed everything I went by the factory cutouts in the rubber backing. Ended up toasting 2 masters. Blew seals in #1 and bent the rod in #2. Found the support bars that mount to the pedal assembly, installed them then reinstalled the assembly. I pushed the supports all the way against the firewall and found they were about 3/4 to an inch too far to the right and down so the rod was going in at a bad angle. Redrilled correct holes and NO issues since.
However, even being that far off, the master rod still reached plenty far. You may have to push in the clutch pedal some to attach to the rod but dont push in on the rod itself if the slave is out of the trans.
Old Mar 12, 2012 | 08:17 PM
Holmes's Avatar
Engine: 5.3LSX
Thanks, Maybe I installed the pedals to far away, I'll see if that's the issue. I figured it wasn't the master since all the swap threads never said anything about extending the rod on the master to work properly.
Old Mar 12, 2012 | 08:29 PM
Mudluver27's Avatar
Car: 1988 Firebird
Old Mar 12, 2012 | 08:30 PM
Mudluver27's Avatar
Car: 1988 Firebird
Old Mar 12, 2012 | 08:31 PM
Mudluver27's Avatar
Car: 1988 Firebird
I dont believe its possible to mount the pedals too far away. They only go in one way and to my recolection have no adlustments.
And the black crap in the pic is silicone caulking to seal it up completely and cover the extra holes. Didnt feel like patching it with sheet metal like I should have ... too tight and a PITA.
Old Mar 12, 2012 | 08:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
whats with all the black goop?
Old Mar 12, 2012 | 08:38 PM
Mudluver27's Avatar
Car: 1988 Firebird
Also looks like hell because my car is in pieces doing a complete interior restore.
Old Mar 12, 2012 | 11:17 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Is it possible your master cylinder rod is partially depressed into the master cylinder?
And the pedals mount to the firewall? The whole assembly is a fixed distance from the firewall... are you using third gen pedals?
Old Mar 12, 2012 | 11:26 PM
Mudluver27's Avatar
Car: 1988 Firebird
l
Old Mar 14, 2012 | 02:13 PM
Holmes's Avatar
Engine: 5.3LSX
I think the master may just be bad (depressed into the cylinder), I was looking at it today, (sorry I forgot to take my camera this morning) and the pedals are where they are suppose to be, I waiting on a master cylinder to arrive at autozone later this afternoon to pick up. It can't hurt to put a new one on regardless so I'm hoping thats the cure.
Old Mar 14, 2012 | 02:21 PM
Mudluver27's Avatar
Car: 1988 Firebird
Makes perfect sense.
Old Mar 14, 2012 | 02:57 PM
Holmes's Avatar
Engine: 5.3LSX
Yea, hoping thats the issue, I am using 4th gen pedals for the swap
Old Mar 16, 2012 | 02:25 PM
Holmes's Avatar
Engine: 5.3LSX
How much length of travel does your clutch pedal have?
Old Mar 16, 2012 | 03:02 PM
Mudluver27's Avatar
Car: 1988 Firebird
ALOT... comes all the way to the top. Releases near the top which is why most people go with an adjustable like Tick. I for one, cannot afford that so I deal. But I also dont have to push the clutch all the way in to engage the gears. Idont mind, IT WORKS!!!!
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
