Question Transgo Reprogramming Kit TH700
Old Mar 14, 2012 | 05:14 AM
-Tom-'s Avatar
Hi
I bought a Transgo Reprogramming/Shift Kit for my TH700R4. Now i have two questions, sadly i dident found a E-Mail adress from Transgo and i dont want to call them (to expensive from switzerland).
But i am sure some of you have the same kit and maybee you can give me a answer.
First question.
I have the problem (like everybody with a TH700R4) with 3/4 gear. When i pull the pedal down the car goes up to 190kph/kmh but in the 3th gear, doesent shift to the 4 and the revs are on redline.
When i pull the pedal back till 1/3 the car shifts to the 4th and the car goes faster then 200kph/kmh+. But when i pull down the pedal little more for more speed, it shifts back to the 3th doesent matter what rpms. Of course its dangerous for the engine and i want to pull that pedal down till full speed in the fourth.
My question; Is this problem fixed with the Transgo Shift Kit?
Other question... on the first sheet of instructions i can read that small block needs a other tv valve and i need to order.
Did i understand something wrong?? Do i need this?
Last informations i have a 90 trans am gta (350) with the TH700R4. I go for the automatic mode (not fully stick mode).
I am very thankfull for every answer... once more sorry about my english, i hope you understand what i mean
Thanks, greetings!
Old Mar 14, 2012 | 06:59 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Question Transgo Reprogramming Kit TH700
Talk with Dana from this website or his http://www.700r4l60e.com/ His Email is on his site.
Old Mar 14, 2012 | 07:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The TransGo kit usually doesn't fix the 3/4 WOT up shift. This link shows how to modify the TV valve set up for full throttle WOT 3./4 shifts:
www.joby.se/corvette/mods/2002-0X02_tranny_wot/
Note that instead of threading/tapping and using epoxy, can use some short set-screws and thread them in (self threads).
I'm not sure about this. IIRC, there is something about a TV valve spring. Although I can't find the instructions at this moment.
RBob.
Old Mar 20, 2012 | 02:53 AM
-Tom-'s Avatar
Hi
Thank you very mutch for this information.
I know about this tv valve mod, but was not sure if the shift kit fix this problem anyway.
But now i will do this mod when i install the shift kit, and my engine will be thankfull for sure
Greetings from switzerland!
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
lt1z350
Aug 28, 2015 05:57 AM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
