Anyone know to Pinpoint the Clutch Master Cylinder Position?
I did and entire T5 swap only to have it die 6 months later. My master slave cylinder wasnt aligned perfectly, it blew the cylinder. I ripped the entire car apart before coming to that conclusion.
It was the Mcloeds Adjustable unit-They sent me a replacement but im not sure if the hole I drilled is accurate.
Every step of the T5 process is pretty simple except where to drill the hole for the master slave. Does anyone have the exsact measurement from a factory car?
This would help me out and maybe anyone else out there.
Car: 1988 Camaro Iroc-Z Convertible
Axle/Gears: 8.8 with 4.10 Gears
Re: Anyone know to Pinpoint the Clutch Master Cylinder Position?
If you don't get anything by next week I'll be headed back to the junkyard to pull some parts off a factory 5 speed third gen. I can get you some measurements then.
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
You should have 2 support bars that come down and land against the firewall. Those will give you your u-bolt mounting drill points. Then you use a 1 3/4 hole saw in the center. You have to elongate the hole towards the top for the master to seat properly. It will end up an oval. I used a rasp for my drill and it worked great. Make sure you hook the master to the clutch pedal before tightening down the u-bolt nuts.
I went through 2 masters before I figured it out.
i did that- my hole was off by maybe 1/16 of an inch. which caused the piston inside the slave to rub against the wall-of itself.
There is so much room between those two holes. I want to be exact if I am to do this again. If you look at my other thread it took me 20 hours or more to rip apart and figure out what was wrong with my setup, I wouldn't take another chance.
Thanks V8SC- it would be appreciated if you got that info.
Car: 1988 Firebird
Damn man, I hope I got mine right this time. Seems to be. But if it took yours 6 months...... If it breaks again I am going to commit vehicular homicide (to the car).
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
1/16 will make no difference at all. you must be off more than that, or have a defective piece.
I installed the pedals, and made the holes in my 86 where the supports landed, been fine for years, did no crazy measuring.
my t5 swap in my 92 i currently working on uses 4th gen pedals, the support is a lot more flexable than the stock 3rd gen stuff, so i places a straight steel ruler against the side of the clutch pedal, right at the pin and to the firewall and used that as a mark to measure from.
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
^X2.
I blew my first master and slave, but they were used.......bought new and no problems since. FYI Advanced Auto has the nice aluminum slave unit.
I also used the pedals as the template, and cut the hole into an oval from there.
i scrapped the entire car because of this. It was indeed the mcloeds master cylinder. And it was off by about 1/16. They sent me a new on but by then I could care less the car had a bent frame and now no trans and a crappy drum rear. Abort.
But I do have my brothers 86 Iroc (he died) That he left me and as soon as my dad takes the keys out of his butthole Id like to drop a t56 in it.
So that being said : IF ANYONE HAS THE EXACT MEASUREMENTS for where the Stock hole is supposed to be drilled: It would be very much appreciated.
As i can see this information would also be useful to anyone else doing the swap. Even though I hear lots of people do this without a specific measurement. My auto Z28 had NO holes of any kind for the MS or pedals or anything.
Car: `86 SS / `87 SS
The stock hole is slightly slotted.
Secondly, the bolt holes are what locates it.
Thirdly, McLeod had some issues over the years with their master cylinder.
Fourth, the T5 takes a 3/4" bore master cylinder; try a stock one instead & sell the McLeod.
Fifth the pushrod doesn't have enough angle to **** the master cylinder piston in the bore unless you've really goofed, so don't assume that was the issue that caused the McLeod issues.
Sixth, good luck w/ the new-to-you IROC and sorry about your brother.
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:17 AM
