Spider gear install
Old May 5, 2012 | 04:02 PM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Spider gear install
I made the mistake of turning my OPEN differential when pulling out the c-clips and both spider gears fell out too.
What's the trick to putting them back in w/o having to fully disassemble everything?
Art
Old May 5, 2012 | 04:08 PM
Re: Spider gear install
Not too bad really...
Remember that the side gears and the spider gears have to all coincide with where the axles need to be.
Each individual small gear has to be put in in such a way that when the carrier gets rotated to where the axles will go in, the small gears line up again. Usually easiest if you put in one spider gear, then line up the 2 side gears to it, then slip the axles in enough to keep the side gears from falling out again, then rotate the carrier until you can just barely get the other spider gear in, then slip it in and hold it while rotating the carrier in the appropriate direction.
Old May 6, 2012 | 01:15 AM
Arvizu9618's Avatar
Thanks Sofa, I got 'em back in with ur advice
RT
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
camaro11j
Sep 19, 2018 08:49 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
