168 tooth flywheel with t-5?
Car: `86 SS / `87 SS
Re: 168 tooth flywheel with t-5?
Draw a vertical line through the two right bellhousing bolt holes.
A 153 bellhousing has a starter pocket inside that line. All V8 third gen bells are like this.
A 168 bellhousing has a starter pocket outside that line, required for the 168 starter to fit.
Buy a non-stock type 153 flywheel or run a weight plate between the crank and flywheel.
Yep. The Quicktime one probably does too.
So what do guys with 383's do?
We take our stock L69 flywheel to the balance shop and have it "unbalanced" to the stock 400 spec.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Yeah I did a little more goohling and found them.
Shoulda waited a little longer before posting.
Finally getting back to the old project car, and putting it back on the street.
monte87cortez
Sep 26, 2015 08:10 PM
