VSS Speedo "Driven Gears" in an 89????
Old Mar 24, 2012 | 02:54 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
My car is an '89 RS, and I bought the one-piece plastic driven gear to correct my speedo. When I popped out the existing driven gear, I was surprised to see this:
I did not think VSS started until '90. Why does my '89 have this setup, and not the one-piece plastic gear that other cable-driven speedo's got?
Also, is there a correct way to remove the metal shaft, or insert the shaft onto a new gear? I tried pulling, and you can see that I broke a piece off the back of the gear. When I get my new gear, do I just press the metal shaft in with my hands?
Old Mar 24, 2012 | 03:27 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: When Did VSS Speedo "Driven Gears" Start Appearing?
Firebirds got it around 86ish I think....
Old Mar 24, 2012 | 05:46 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Metal shaft, plastic gear setups like yours go back decades.
There's some interchange of the 700-R4 driven gears with other GM model transmissions too.
Use of the gear only as attache to a VSS was 86-up in Birds, 90-92 in Camaros. Trucks went to reluctor wheel / magnetic pickup VSS around 89.
The inner part of the gear has a thin plastic sleeve with a retaining rib that fits at the bottom end of the half-moon part of the shaft. If you use a pick to hold it up, the shaft can sometimes be successfully removed without bearing the gear.
Old Apr 5, 2012 | 04:23 PM
PLEASE HELP ME!
I'm sick of throwing money at the wrong parts. What do I need???
Started with a 2.73 rear, swapped to a 3.42 rear.
When I pulled out my old driven gear, it looked like this:
I broke it when I removed it, so I ordered another. You can see that the new gear does not fit on the shaft:
So I bought a the older, non-vss gear that I thought should be in the car to begin with. It will not even fit in the housing:
WHAT DO I NEED??? I realize I have alot of different colors/tooth counts going here, and at this point just want to be able to drive the car. I'm sick of buying the wrong parts. Do I need a different gear housing to use the black gear above?
Old Apr 5, 2012 | 07:06 PM
jmd's Avatar
jmd
Re: VSS Speedo "Driven Gears" in an 89????
What's the inside of the new green(?) gear look like compared to the old red?
What PN are the black and greens?
Old Apr 6, 2012 | 06:17 AM
The black 40 tooth is part number 1362048, and came in its original NOS box. I paid a small fortune for it.
The grey 44 tooth is part number 25513051
In this pic, the original red is on the lsft, beside the new red and grey. You can see that the old red had something on the back to hold the metal shaft on. I'm guessing the gear is not supposed to come off?
Old Apr 6, 2012 | 02:30 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
help this guy i need help to
Old May 8, 2012 | 10:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the 40-45 use a different vss. Standard motors sc13 I'm thinking would work. but I think it would have a 4k output so a dakota digital sgi-5 would need to be used with maf tpi.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
cheesehomer
Dec 31, 2015 08:48 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
