TV cable question, possible damage
Old May 14, 2012 | 08:48 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
question:
When I originally removed the trans from donor car I lowered the trans and didnt unhook the tv cable within the trans ( the actual hook that goes into the little hole), I did unbolt the housing but didnt unhook it. Could I have stretched something or bent something within the trans?
How can I check it for damage?
The cable is properly setup with the proper tension too.
Issues I am having is that it doesnt seem to downshift properly and my upshifts are to fast. Thinking that the upshifts I can handle with the governor, But the downshifting is all the tv cable right?
Old May 14, 2012 | 03:00 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: TV cable question, possible damage
Bump
Old May 14, 2012 | 04:00 PM
Cosmik Debris's Avatar
The TV cable adjustment affects upshifts. The governor only changes the full throttle shift point. I would replace the cable personally.
Old May 15, 2012 | 02:57 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Would that cable stretch? I was worried about the part within the trans that it connects to possibly being damaged. Could that be? if so how to check that?
Old May 16, 2012 | 10:35 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Drop the pan, remove the TV linkage, post a pic. Do a new filter while you have the pan off.
Old May 16, 2012 | 11:01 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
I have already done the filter when I put the motor in. What would I be looking for when I would drop the pan? I mean as far as the linkage goes..
Old May 16, 2012 | 11:19 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I can post a pic of how it should look. Probably late tonight.
Old May 16, 2012 | 04:53 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
ok, that would be cool. Thanks!
Old May 16, 2012 | 07:22 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Trying to use a phone in bright sunlight didn't result in helpful pics. Maybe I can do better in the morning, I will try.
Old May 20, 2012 | 03:32 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Ok thank. I will be waiting for that
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
